Cycle Analyst with Cyclone 500 Watt Motor and 24v 20ah LiFePO4 Battery
1 post / 0 new
marose1
I have a DreamE bike with 500 watt cyclone mid drive motor (internal controller) and a 24v 20ah LiFePO4 battery. I am considering the purchase of a Cycle Analyst to use as a speed/throttle control.
Ideally, I would like a device that would:
1) Cut off power when I exceed a specified speed and resume power when I reduce below the specified speed; or,
2) Allow a manual setting of specified throttle (1/2, 1/4, etc.) so that I can operate at a specied throttle setting, e.g., 1/2, for extended distances.
Is there a simpler/less costly device that I could use for this purpose?
Is the CA-DPS the model that I require?
Thank you,
Mark Rose
