Watt's Up User Manual
Submitted by Board Moderator on Fri, 07/13/2007 - 11:34
For the convenience of our V is for Voltage Community Members and Guest, we temporarily share files as soon as we receive them. They are latter moved to our growing [node:399] where they will remain. We really appreciate our friends sharing with us, and back them up in several locations for there safe keeping.
Topics:
- boomingheight
- janet
- Bengun
- Skyhawk 57
- wild4
Comments
Re: Watt's Up User Manuel
The "Watt's Up" Watt Meter and Power Analyzer User's Manual is now on the EV DownLoad Library.
Chas S.
My Bicycle Pages
Thanks V Team!
I have a Doc Wattson that is the same as the Watt's Up except that it's good to 100 Amps.
The diagram comes in handy since the wiring is the same.
Unfortunately, I haven't figured out how to use it on my bike since I occasionally have a draw of over 100 Amps.
(and, of course, the fact that it only has 14ga wires)
Wonder if I can re-build it using heavier wire and a different shunt ... :?
Dave
MB-1-E
Dave B
MB-1-E
I completly forgot about the Doc Watson
Any idea where we can get a user manuel for our EV DownLoad Library ?
Peace Out,
Gman
Gman
http://www.rc-electronics-usa.com/ammeters/rv-battery-monitor.html
I'm not sure where my hard copy of my manual is, but will scan it if I find it.
The specs are at the site above and I believe the manual will be similar if not the same as for the Watts-up.
I didn't find the manual online, will need to look some more.
Dave
MB-1-E
Dave B
MB-1-E
The Three Wire Connection is shown here that may work better in some situations ...
Electric Bike Connections for the "Watt's Up" Meter
Example electric bike connections are shown in the diagrams below.
Four Wire Connection (easy to understand)
The "jumper cable" hookup. While easy to use, this approach forces the use of heavy gage wire for the plus lead and increases power dissipation in the meter. It also slightly decreases voltage accuracy at higher currents due to additional voltage drop across the plus lead. The drop is ~0.01 V per 12 A compared to the voltage at the meters source lead tips.
Three Wire Connection (better performance, less wire)
The three Wire hookup has several benefits. This arrangement requires only two heavy gage wires to carry the negative lead current and so is better for remote testing and monitoring. The third, plus, wire can be lighter gage (e.g. 20 gage or heavier) as it only carries the small current required to run the meter itself.
The three wire hookup also allows higher current operation as the heat from power dissipated by high current in the plus wire is no longer present.
Our Meter Links page has a handy wire resistance and voltage drop calculator.
Many other meter uses and arrangements are possible.
Please see the meter's User's Manual for more details and safety precautions.
Diagrams show energy flowing from left to right
Dave
MB-1-E
Dave B
MB-1-E
A larger version of the above diagram is now on the EV DownLoad Library.
Chas S.
My Bicycle Pages
