The Zapino Has Arrived?
32 posts / 0 new
Gman
Gman's picture
Zapino
Product Name: Zapino
Product ID: 99-PIN-01234
Price: $2,995.00
Description: Filling the gaps between Point A to Point B transportation, ZAP has finally found the middle road. The new ZAPINO electric scooter is a great link between ZAP's personal transporters and electric cars.
Not only economical and non-pollutant, the ZAPINO is also powerful with an advanced 3000-watt brushless DC hub motor, perfect for city commuting. Able to reach speeds of about 30 mph, you will be able to keep up with city traffic without contributing to city pollution.
The hub motor in the rear wheel creates more room on-board for additional batteries, greater functionality and performance. This eliminates the need for belts, or chains, resulting in a more enjoyable ride with less vibration and noise, and a smoother acceleration while reducing overall maintenance.
Motor: 3000W Super efficent brushless hub motor
Max Torque: 120NM/900RPM
Max Speed: about 30 mph
Range: up to 30 miles each charge*
Brake: Rear and front disc
Weight Limit: 280 lbs.
Battery: 60V Green saver silicone batteries
Net Weight: 297 lbs. (including battery)
Optional Upgrade: Replace with 60v40AH Lithium battery
for a range of up to 75 miles
Climbing ability: 25% slope with a 177 lb rider.*
* Factors such as weather, terrain, load may affect results.
3000 peak watts, 60 volts
Intelligent Controller and DBI-digita
This is the most powerful electric scooter in its class
l battery indicator System
* This is the only one in the field of E-Scooters
Last seen: 6 days 11 hours ago
Re: The Zapino Has Arrived?
3KW-rated motor, 60 volts, but restricted to 30 mph. What's the point of that?
leio
Do you know the company ?
I was told they were specialists for communication and announcing vehicules with great specs :) and then... nothing :( .
I agree with the strange 3000W 60V => 30mph restricted and only 30miles range !!! :?
=D-----------born to be wired-------------C8
davew
davew's picture
It would be interesting to find out what the lithium upgrade cost. I am a little dubious about how "super efficient" that motor can be with an E-max style battery pack and less than emax specs. I am very dubious about Greensaver batteries. There is still no domestic source, their quality control blows, and I swear the next person who claims these batteries are environmentally benign is going to have to eat one to prove it.
Full time ebiker
BionX and Wilderness Energy
Last seen: 1 year 1 month ago
The 30 miles/hr max is probably because (in California) it makes it a moped and has lesser license requirements. Many scooter makers also use the 30 miles/hr max.
Gman
Gman's picture
I agree, I believe it's the same in a lot of places
City of St. Louis Ordiance 66692 states:
"Motorized bicycle" shall mean any two- or three-wheeled device having an automatic transmission and a motor with a cylinder capacity of not more than fifty cubic centimeters, which produces less than three gross brake horsepower, and is capable of propelling the device at a maximum speed of not more than thirty miles per hour on level ground, except those devices used by persons with disabilities for the purpose of mobility".
I haven't seen a Mobility Scooter yet that goes over 30 MPH, guess that's there to comply with The America Disability Act or something.
I'm sure there is a increase also in there product liability, and your eliminating the youth segment of your potential market.
In States that require vehicle inspections, what's the standard on E Scooters etc?
If Mountain Chen is correct about Zapino having samples of his 3000 Watt Lithium Power then that's a whole different area. I need to confirm the: Max Speed : 110 Km/h (110 kilometer/hour = 68.350 831 146 mile/hour ) that seems kind of high to me.
Peace Out,
Gman
Gman
borgbike
borgbike's picture
- David H
This is frequently the case with under 50cc scooters in most states. Many of these scooters are restricted to this speed limit with slugs in the exhaust and/or some sort of electrical or mechanical rev restriction.
As a pretty serious scooter enthusiast, I can say with some authority that it took importers and distributors a while to learn that there is a real market for higher cc scooters in the US. In around 2000 when you started seeing more scooters brought in to the US, most were 50s. Their reasoning was that most potential consumers didn't want to be hassled with getting a motorcycle license. People who wanted something larger would opt for a motorcycle. This reasoning turned out to not be so accurate.
I'm still waiting for a proper electric scooter, one that would have the speed and performance capabilities of a normal (non-50cc) scooter. Current Vespas are sold as 50cc (two stroke), 150, 200 and 250. (The latter three all use four cycle engines.) I see way more Vespa ET4s and LX150 than the equivalent 50cc versions.
Realistically I will be happy with an electric scooter that is equivalent to a derestricted 50. My personal preference would be to sacrifice a lot of range for good acceleration and a higher top speed. If I could find a scooter with with a real range of maybe 15 miles and a real top speed of 40 I'd buy it.
It would be interesting to know if the Zapino could actually go faster.
cheers,
Dave
Gman
Gman's picture
I have to agree with you. It's my understanding Zaapino currently has a sample of a 3000 Watt from Erato that will do 49 mph max.
There is also a 10,0000 Watt on the horizon, especially made for export to Europe and the USA.
Wisking Electric Motorcycle: Next Step 72V High Power Motor 10000 Watts 62 MPH ?
, for some unknown reason it keeps getting moved to Product Announcements which explains why no one has seen it yet.
Peace Out,
Gman
Gman
kringle777
kringle777's picture
Borgbike,
You said, "If I could find a scooter with with a real range of maybe 15 miles and a real top speed of 40 I'd buy it."
The XM-2000 does that right now. In fact, it does a bit better than that. My commute to work is exactly 7.5 miles each way, and I get home still in the green zone on the remaining charge indicator. I don't have a GPS, but I blend in quite well with cars going 40+ MPH, so I'm reasonably sure I'm doing something around that speed.
So, that's available now for about $1500.
Now, this Zapino at 3000 Watts would undoubtedly have better acceleration, which would be huge benefit. And the quality sounds really good too. Lithium would be a plus, nobody doubts that. Just get rid of that 30 MPH restricter.
And is it the way the picture was taken or does the Zapino seem kinda small? Maybe the lady in the other picture from the Zapino testride is tall....
kringle777
Red XM-2000
Moss Green "Charger" ebike
Sacramento, CA
kringle777
Red XM-2000
Sacramento, CA
Gman
Gman's picture
Borgbike,
That's amazing, a couple of questions, your weight, road level or any inclines, can you have a car pace you if you don't have GPS, or total miles in how much time non stop for a open stretch of road.
I'd get a speeding ticket here on most Streets other than the main drags where the speed limit is 35 MPH, every where else it's 25 mph.
17.10.030 City wide speed limit.
The City wide speed limit shall be 25 miles per hour. The speed on any street or park road in this City shall not exceed 25 miles per hour unless otherwise posted. (Ord. 57831 § 1 (part), 1979: prior: 1960 C. § 824.030.)
Am I correct, your in CA and had no problem getting it registered? Have you tried any of those famous Frisco hills yet?
Seems like you got a pretty good deal, and probably very lucky. I'm still very reluctant to spend that much on anything from X-Treme, until I read more positive statements like yours.
Peace Out,
Gman
Gman
kringle777
I weigh 210 lbs. The streets are relatively flat here in Sacramento. Little nudges here and there, but no hills. The speed limit for most of my route is 35 MPH. To confirm the exact distance, I mapquested and local.googled the exact route I take (by the way, local.google.com has this awesome little dragging capability that you can use to modify your route to go exactly the way you want).
My wife paced me in her car the first day I got the XM-2000 and said I got into the late 30's on the little stretch of road that I did the test on. The XM-2000 is obviously slowest (for me) at takeoff. Traffic is most likely to want to go around me at only that point. That's why I'd like to shed some pounds and improve that area. But once it's in high gear (past 20-25 MPH) it doesn't seem to have any problems accelerating throughout the 30's and 40's, even with me on it.
I'm gonna have to find me a skinny person to road test it for me to see if my diet plans will bear fruit. My wife would fit, but she's scared of going fast.
As for registration, following John in Ann Arbor, I sent in registration as a moped. Got insurance for it too, no problem there. Still waiting to see what X-Treme does about the MSO and the VIN tags though, gotta admit that.
kringle777
Red XM-2000
Sacramento, CA
kringle777
Red XM-2000
Sacramento, CA
Yep - I second kringle. My XM-2000 tops out at about 43mph and has a range of at least 22 miles. Probably more - I was concerned about the charger and haven't fully charged my batteries yet. My worries were unfounded (apparently you should ignore the documentation :? ) I'm gonna fully charge them tonight and commute to work tomorrow (12 miles one way - but I'll charge it when I'm there - so that I can let all my friends try it out ;) )
Later this week I will hook up my GPS (actually (a) find it & (b) charge it) and go for a ride.
I'm 150lbs and there are some moderate hills where speed drops below 30mph. Like kringle it's acceleration up into the 30s when people want to pass you. Once up to speed I don't hold up traffic on anything but 45mph (and above) roads.
I registered mine as a moped by going into the Secretary of State and saying "I want to register my moped". They accepted a signed bill of sale which had the VIN as supplied on it. I'm not sure what the exact issue with the VIN is. Unless they all have the same one? (Kringle - I'll send you a message and I'll show you mine if you show me yours ;-) ) The VIN all checks out in terms of an appropriate manufacturer, year, check-digit and serial number. The MSO is a different story - I hope X-treme can sort that one out soon.
John H.
Blue XM-2000
Ann Arbor, MI
Gman
Gman's picture
Typical DMV, one place it's easy and simple, then another place you have to take the Scooter in so they can check the VIN number, and both places are in the same state.
Like I said your lucky, can you give me 5 numbers between 1 and 55 and 1 between 1 and 42?
Peace Out,
Gman
Gman
ScootGreenly
I just got my Zapino, and absolutely love it. I've gone on two 23 mile trips, much of it at around 40 MPH, with nearly the maximum load (about 270 lbs) on mostly level ground. This is my first motorized bike of any kind, but it's such a blast to ride that I'm looking for excuses to take it out.
A longer range would be great - I'll try the Lithium batteries at some point I'm sure - but otherwise my only complaint is that I won't be able to take my kids on it for long because our combined weight is approaching the limit too quickly. [For the record, only they are growing :-)].
thakaluke
thakaluke's picture
Nice, where did you purchase it from?
VT-01
VT-01's picture
Greetings ScootGreenly and Welcome back Thakaluke,
Welcome to the V is for Voltage Community!
That Zapino sure is an eye-catcher, we're anxious to hear more about it.
Don't forget to check out our V is for Voltage Community Library we're adding new information all the time .
VT-01
Moderator Team
Moderators are dedicated volunteer V Team members who help keep your V Forums running smoothly and provide Forum Support.
VT-01
V Moderator Team
Moderators are dedicated volunteer <a href="http://tinyurl.com/2wan5x"> V Team</a> members who help keep your V Forums running smoothly and provide <a href="http://tinyurl.com/ytx8gz">Forum Support.</a>
Gman
Gman's picture
`ScootGreenly,
Welcome to the V is for Voltage Community, we are anxiously waiting to hear more about your new Zapino, maybe see some actual up close pictures.
Peace Out,
Gman
What is your vision for the future our growing community?
Gman
Mountain chen
This photo is LFP lithium battery samples of ZAPINO,silver colorLithium_battery_pack.jpg
Gman
Gman's picture
Mountain,
One problem was, someone had placed this in Product Announcements, and very few viewers go there.
I was wondering why there wasn't that many replies, it should do better here.
Peace Out,
Gman
Gman
Mountain chen
Dear davew:
No need to compare ZAPINO with E-max battery problem.
E-max use 8pcs 20AH battery complicated in series and parallel to compose 48V,their max current on boost button is 90A,big damage to 20AH battery.
ZAPINO use 60V big battery system,max current only 55A,less damage to silicon battery.
They come from different silicon battery supplier. see photo 60V_battery.jpg
Gman
Gman's picture
Mountain,
Do you have a spec sheet or something you can post or send me?
Is this the Battery layout for the 2000w Lfp Lithium Power Scooter?
Peace Out,
Gman
Gman
Mountain chen
Dear PJD:
We have 2 speed switch on throttle....at 30mph and at 45mph....see photo
Gman
Gman's picture
Mountain,
I assume Zapino is the only place in the US that currently carries your 3000w Big Size E-Scooter?
Since we all don't live on the West coast, what about us in the middle of the country, close to the Gateway Arch were I am?
Peace Out,
Gman
Gman
Mountain,
Thanks for the info and the posts.
1) What is the weight and the amp hours of the Lithium configuration you show? I notice that you've filled almost the entire space that were used by the lead acid configuration
2) What is the cost of the Lithium configuration you show?
3) Am I right in guessing you are using cells from Thundersky? (based on the visuals only)
4) What does the speed control switch do? Does it apply limits in the controller or does it change the power characteristics of the motor? Or does it change gearing?
GMan,
What you posted looks very much like am XM2K frame with Lithiums installed. What Mountain posted was a different frame.
Many thanks,
John H.
Blue XM-2000
Ann Arbor, MI
http://www.revevllc.com
Gman
Gman's picture
That's correct, if you notice I posted 2000 Watt which I beleive he no longer sells.
China Erato Electric Vehicle Manufacturing Co.Ltd
All our 2000W60V scooter have been update to be 2500W60V automatical motor (no button needed),it is more powerful and bigger torque with rear/front disc brake....
New technology Nanometer high capacity battery will bring a revolution in field of EV,it is lighter than Lithium battery and more stable,no burn,no explode,1200 life cycle and 20minutes quick charged.
18 months of bulk production experience in field of ON ROAD electric motorcycles ensure of our reliable quality and good after sale service. Worldwide viewing,only EVT and E-max have such experience of hundreds pcs bulk prodution ! Other chinese factory only have sample experience....take care if you want to buy cheap scooters.
Our scooter are hot sale in USA www.greenemotor.com and www.x-tremescooters.com, www.electier.com , http://www.evworld.co.nz/products/new-products/ ...etc. San francisco,Soul,Newzealand are the most steep road city in the world where accept our scooter have proved the best Torque of our motor.
Peace Out,
Gman
Gman
Gman
Gman's picture
`Mountain,
This is what we call off topic, can you post a comment to this thread? Wisking Electric Motorcycle: Next Step 72V High Power Motor 10000 Watts 62 MPH ?
Peace Out,
Gman
Gman
zaprider
I have been riding a Zapino for the last three weeks. It is my first scooter, and I think it is great.
I ride approx 4km to work and back every day in Charlottesville, Va. I would certainly recommend it.
(1) However, Mountain Chen's claim that the switch changes between 30 and 45MPH does not fit my experience.
In my experience, on flat ground, the low switch limits the speed to 22MPH and the high-speed switch allows
it to go up to 32 MPH. The distance meter on my Zap seems to be counting kilometers, so perhaps Mountain Chen was
quoting KMs.
(2) Perhaps there is a limiter which can be removed to achieve those speeds. If so, can you please let me know how to
do that?
(3) The battery meter on the bike consists of 4 LEDs. I consider this a poor measure of the charge left in the scooter. After approx 1 week, the first three of these lights no longer seem to work. The bike, however, seems to have a charge and travels far enough. I measured the 5 batteries, and noticed that after a full charge (as indicated by the charger), 4 of them are at 13.3v while the 5th one is at 13.1v. There are no battery balancers in the bike. How can I fix the situation?
Thanks for your help.
Hi zaprider,
Glad you like the bike. As far as #3 goes do a search on PowerCheq or BattEq on this site. Both these products are designed to balance your batteries. One one battery is out of balance it can have a domino effect and ruin all batteries in the string.
I use the PowerCheq's on my bike (4 x $60 = $240). Kringle777 has just ordered the BattEQ product for his bike (a 5 battery system for $199).
John H.
Blue XM-2000
Ann Arbor, MI
Mountain chen
Gman,
take care of Wisking,they just cheating from sample charge,they have nothing.... you may ask them to send Video or photo to confirm....also Dymo testing sheet to find out what is 10000W ,they maybe say about 200000W to attract people's eyeball..
Act as QC of ZAP,I went to Wisking half a year before,they just 3 samples modified from 500W scooter,very bad quality and no production,no VIN number .....no allow to visit workshop where is nothing actually.
Mountain chen
Wisking just like Evader 2 years before.... cheating a lot but nothing on market.
They hurt a lot of unprofessional clients in this field.
Mountain chen
Dear Zaprider.
I think what you bought is the climbing version ZAPINO on which we reduce the RPM (speed) of copper winding inside motor to increase the torque,consider the steepy road on Sanfancisco.
We have another speed version which is more RPM,top speed could reach 73km/H on flat road,but less torque than scooter in your hand.
Re Digital Battery Indicator,since this is first DBI panel,the quality is not stable,I think it is LED light connecting problem.We will take care and improve it !
Unlike voltage meter,BDI don't drop when you full throttle accelerating.
Thanks for your feeback.
