brushless controllers for kollmorgens?
3 posts / 0 new
rpmarco
rpmarco's picture
hi all,
i'm modding my 400w koll for a project...had no problem rewiring for CWR on a previous project, but now am running into a problem finding a 48v controller for the motor i am gutting. noticed a chinese dealer on ebay selling 600w brushless controllers fairly reasonably priced (except for shipping) but would like something with closer to 40A max. i guess my question is whether my assumption that i need a BRUSHLESS controller for this motor is correct (judging by the 3 phase wires vs. 2 on other brushed motors i have). am also wondering if a brushless controller is necessary, does that mean it will require a 5k pot vs. a hall-effect throttle? really don't want to spend $100+ on a controller...if need be will go with one on ebay. any help would be appreciated. i will be sure to post pics of my bike when done--a Swiss Army replica, 48v w/ 3 speed transmission. thanks.
LinkOfHyrule
LinkOfHyrule's picture
Re: brushless controllers for kollmorgens?
Hate to break it to ya, but brushless controllers are kind of pricey, especially at over 20A or so. Those ones from e-crazyman on eBay are about as cheap as it gets. Even modifying one will run you close to $100, due to the number of replacement FETs and capacitors.
Whether you need a pot or hall throttle depends on the model of controller. Most controllers of the size used in ebikes and scooters are hall.
IbeRKT
You are going to be hard pressed to find any 48 Volt Brushless controller for under $100 anywhere, especially at 40amps (and yes that motor requires a brushless controller). I have been searching for brushless controllers myself and here is what I found.
First is the POWERPACK MOTORS 24-48v BLDC Motor Controller for $169.95
http://www.powerpackmotors.com./Powerpack-enhanced-shipping_included.html
I don't know what the amp rating is but you can email them and ask (powerpackmotors [at] socal.rr.com)
Another option is this controller used for e-bikes (36V 35A Start Immediate Controller, can be used up to 48V) for $170.00 but it's only 35amp
http://www.ebikes.ca/store/#BatteryAcc
If you really want high amps for a brushless controller you are going to have to pay a little more for the Kelly controller. You would want to get model KBL48101 it is rated for 48 volts and 60amps continuous cost is $229.00
http://www.kellycontroller.com/mot/Brushless-DC-Motor-Controller.html
The only other option that I know of (for 48 volt brushless) is the very expensive Millipak PMAC 36-48 Volt 200 Amp AC controller with regen for Brushless Etek for $480
http://www.electricmotorsport.com/PARTS/parts.htm
Hope that this helps.
