E-Max charger failure
48 posts / 0 new
Starvid
Hello everyone!
I have been lurking here for a bit and decided to join now that I have taken my E-Max 1500 out of storage after the long Scandinavian winter.
A bit irritating though, the thing won't start as the battery is depleted and the chargers have failed for some reason. Both of them. The small red light signalling that they get power is still shining when they are plugged in, but the blinking red light which should blink when it is charging, refuse to blink. And refuse to charge too. It's sucking in a measly 13 W, which I guess is how much those two little red lights use. When charging with both chargers it's usually around 700 W.
Anyone know what might be the problem?
Gman
Gman's picture
Re: E-Max charger failure
Hey Starvid,
I don't know about Emax, but I had the same problem with my 48 Volt Smart Charger, the Batteries might be too low for the Charger to kick in.
I had to charge each individual 12 Volt up to about 12 volts, and then use the 48 Volt Smart Charger. I used a 12V/1500mA AC-to-DC Power Adapter and a Hobby Power Leads Adaptaplug and several small alligator clips.
It's also a good time to see how unbalanced your Batteries are.
Peace Out,
Gman
Gman
Last seen: 4 days 22 hours ago
The e-max charger has a logic circuit that requires a minimum battery voltage to initiate charging, but I'd think this voltage would be pretty low. As Gman wrote, you may need to charge the batteries individually with a cheap 12 volt charger...
But then the question becomes, how did you pack become so discharged? I've left mine sitting for more than a month in temperatures as low as -20C with very little discharge.
And, if has become so discharged (presumably less than 10 volts per battery) then, sorry to say, the batteries are probably ruined. So much for those "silicone" batteries - one more product of Chinese-style free enterprise....
...and I would not normally use both chargers - such rapid charging is never good for the batteries - regardless of the claims made by e-max - who were, in turn, taken by fraudulent claims by the Chinese battery manufacturer "guineng".
Starvid
I'll have a run down with the dealer where we will look the entire machine over, it has after all gone more than 2000 km.
I'll mention the separate 12 V charging.
He did sound a bit worried about the batteries being ruined. Hopefully they are not. Can they be replaced by ordinary lead acids then, because I guess I won't be able to get hold of guinengs?
Strange though about the batteries losing all charge. They have been in storage for a few months, but I have full charged them a few times, as per instructions.
We'll just have to see.
I'll report back, and thanks for the help! :)
The silicone batteries can be replaced with lead acid batteries of comparable battery dimensions and capacity. You will get comparable or better performance. Because of unavoidable variability in eight batteries taken from stock, I consider using battery balancers like the "powercheq" or "smartspark" to be mandatory in a replacement battery pack. The batteries should also be rewired into four pairs-in-series, rather than strings of four in parallel. I recommend BB battery model EB20-12. So far, my e-max is running fine on these, but I haven't ridden it more than 15-20 km on a charge yet.
mf70
Actually, it's pretty easy for the batteries to lose all charge. All it takes is a VERY small unswitched load, such as a "battery low" LED, left on for months. Let us know if you get them off zero volts!
As PJD said, buddy pairs are the best way to hold eight batteries, though you want to make sure each pair is equally loaded, with one lead to the rest of the pack frm each battery of the pair.
Battery balance is also important, and Powercheq's are one way to do this. You can also use four 12V chargers in parallel, or a series/parallel switch arrangement.
Mark
Starvid
Ok, the batteries are dead but the chargers are working fine.
The new ones I am looking at are 4 Biltema 19 Ah lead acids and 4 10 Ah lead acids.
The total cost will be 4*298+4*149=1788 kr= $258
Does this sound resonable?
What technical specifications of the batteries are important, which should I control?
ILBCNU
Why would you mix batteries? The pack is only as good as the lowest common denominator, in this case 10AH. Because your lowest common denominator is 10AH you can only use 10AH to match it from the 19AH batteries so your total AH rating in this configuration is 20AH. This means you can only get 10AH of useful power at 50% discharge. If you just use the 19AH batteries you can get 9.5AH at 50% discharge and carry less weight. Using only the 19AH batteries will save money and with the weight savings you should get about the same range with better performance.
I have always been told "Never mix batteries".
ILBCNU
V is for Voltage
Moderator Captain
Chas S.
Moderator Team Captain
rgx
"What technical specifications of the batteries are important, which should I control?"
Well, obviously they have to fit in the scooter. The e-max has very specific places for the batteries, so there is not much room for improvisation. Obviously you are looking at the 181 x 76 x 167 mm, 6.3 kg, 80-413 (298,00 kr) which should fit perfectly. Second attribute to look for is if they are made for deep cycling (they seem to be) and are made for installation in a vehicle - with regards to vibrations etc. (seemingly yes, that as well). Thirdly when comparing performance, you need to look at the capacity at the expected discharge current. In the case of the e-max that is around 40 A, or 20 A per string, with peaks up to 72 A (36 A). The specification says the capacity at 18 A is 8.1 Ah. That's not great, but at least it's honest. The best comparable batteries could give 12 - 15 Ah when discharged at 18 A. So don't expect great range if installing these batteries (8 of them). Otherwise they are a perfect fit. (Other parameters such as charge voltage and current should be checked as well but they are similar for most of these batteries. Should be OK in the e-max.)
Best regards,
Rolf
Starvid
I am very happy and thankful that you guys help me with these things. I don't know anything in general about batteries, and the only thing I remember from highschool physics is that voltage in volts times current in amperes equals output in watts. :)
I only want my damn scooter to work.
So, I am looking at the 19 Ah ones, with the mesasurments that do fit. And I am to get 8 of them?
This is the info sheet of the battery, in Swedish, but I guess that won't present you with any problems.
http://www.biltema.se/Archive/Documents/Technical_docs/all/80/80-413.pdf
Ok, cycling.
Life time when used for cycling:
Dishcharge 100 %, 250 cycles.
Dishcharge 80 %, 350 cycles.
Dishcharge 50 %, 550 cycles.
Is this good enough?
It says that charge voltage at cyclical charging is 14,4-15,0 V and maximum charge current is 5,4 A.
Can I use both E-max chargers then?
And what do you think my range will be with eight of these 19 Ah batteries? With the guinengs I usually got about 60 km (I weigh 65 kg).
And finally, what are these other best comparable batteries?
Thanks for all the help. :)
Starvid
These batteries were recomended to me by the dealer who told me that the scooter currently holds four 20 Ah and four 10 Ah (broken guineng) batteries.
So he checked up on batteries that fit in the battery case and had the closest Ah ratings.
rgx
There's a long thread about e-max batteries and recommended replacements.
If it is really an e-max 1500 and not some clone or modified unit it should have space for 8x20 Ah batteries, 181x76x166 mm and about 6.5 kg each. You can verify this by lifting out the seat and the "bucket" beneath it, and see for yourself. Only need to unscrew three screws, takes a few minutes. (The complete manuals can be found here.)
The biltema batteries will fit and it will work, but range will be limited, a lot worse than with the OEM units. You'll be the judge if you can live with replacing the batteries after 250-550 cycles, depending on how deeply you discharge them. Also count on that the listed cycles are measured in lab environment, in room temperature, and with low discharge current. Real world number of cycles will be a lot less. So I guess it depends on what you need. If you use the scooter daily, for 20-30 km trips or more, avoid biltema and expect to pay around twice as much for a set. If you'll only drive a few km on sunny Sundays, biltema batteries should work fine.
The e-max chargers are labeled "10A" but deliver around 6 A each, or maybe a bit more at the start of the charge when battery voltage is low. With two chargers that would be more than the 5.4 A recommended by biltema. One charger should be fine.
However, remember that the charging current is divided between either two series-strings in parallel in the factory setup, or divided between parallel-pairs in the "improved" setup. So, assuming even a 10 amp charging rate, this is only 5 amps per battery, so the e-max charger is OK.
Starvid
Well, I need the damn range. Biltema is out of the question then.
Oh well, messing up the batteries has been an expensive mistake, but I guess those are the ones you learn something from.
Having looked at that thread it seems the best ones are the EB20-12, made by BB Batteries.
I guess I need eight of those?
Do you know if those are available in Sweden? I'll mail BB and ask them, but anyway...
And do I need to rewire anything from the original wiring? Are the current ones serially connected and should be parallell, or something?
And what are these Powercheqs everyone is talking about?
Good thing I know an electrician who can help me with all this when I get hold of new batteries. :)
By the way, thanks for all this immensely useful help.
The recommended re-arrangement of the batteries, with the powercheq battery balancers if you can find them, is shown here:
//i109.photobucket.com/albums/n77/PJD123/BatteryRewire.jpg)
Starvid
Are the green squares the Powercheqs?
And where can I buy Powercheqs?
SMAC
Last seen: 17 years 2 hours ago
PJD:
Will your battery wiring diagram work without the powercheq's? I've installed the lead acid batteries you reccommended, but I wanted to be sure that your diagram would work w/out the PCHqs before I attempted it. Thanks for all the help!
It will work without powercheqs. The original pack didn't have them.
But, I had figured that the battery packs was originally assembled with batteries that were tested and matched for similar performance, or the pack was made batteries of the same lot numbers or sequential serial numbers to increase the chances of consistent charge/discharge behavior between each battery in the pack.
This stuff is standard part of QC if you are a manufacturer. But it is difficult for a retail buyer to do it, so I figured the use of powercheqs takes on additional importance for a home-assembled battery pack.
The manufacturer of powercheqs is here:
http://www.powerdesigners.com/powercheq.htm
And another product that seems to be an improvement over th powercheqs here:
http://www.smartsparkenergy.com/prod_batteq.htm
You would think that some sort of battery pack equalizer product would be available in Europe. Have you tried an internet search?
But absent powercheqs, you may want to check the batteries for serial numbers, lot numbers, or date/time stamps on the case. Hopefully, they were manufactured on the same production line and same shift.
Starvid
So I guess I need three Powercheqs, right?
Please be aware the PowerCheqs must be disconnected when the batteries are in storage. They will continue to balance the batteries right down to 2-volts. This in itself will cause a stored pack to discharge faster than normal.
When storing lead acid batteries it is a good idea to give them a charge about once a month. I plan to disconnect mine, then using simple jumper wires connect them in parallel and use a 12-volt battery minder on them. I have a battery minder on my backup generator which keeps the starting battery charged and ready for use at all times. The battery on my generator is 7 years old and still starts the generator every time. The battery minder has been on the battery from day 1 and has never been disconnected.
Chas S.
My Bicycle Pages
My e-maxs were left up to a month and a half without charging and the powercheqs connected last winter. They had discharged only a small amount - less than a half-hour recharge needed to top them off.
PJD,
I am glad you were much luckier than I. My batteries were in storage for about 3 months and now they are junk. They were new last year at the beginning of the summer and still had lots of life when I parked the bike at the end of the riding season. I only got 137 cycles from them last year, according to my DrainBrain, so they should have been good for at lease another season. My other bike has no PowerCheqs and it batteries made it through the winter without loosing much charge like yours. Those batteries are 3 years old and have about 60 to 80 cycles and still going. Both bikes use the same 12-volt 12AH bricks in a 36-volt configuration. The only difference are the PowerCheqs.
One other note for all - The bike with the PowerCheqs defiantly has the better performance in both range and power.
Chas S.
My Bicycle Pages
Starvid
That's what I did, and they still went to Hell.
Nex winter I am going to keep the batteries plugged in all the time, but connected to a timer. They'll get 15 minutes of juice per day. Hopefully that will keep them alive.
I am not making this expensive mistake again. :sick:
Starvid
So, I have talked to the retailer and they can't get me the EB20-12's, that is, if I don't order at least 144 of them.
Instead they propose I buy the BP18-12B1. It seems to be okay, with the difference that is it cheaper and only has 90 % as many Ah's.
This is the fact sheet:
The "B1" at the end of BP18-12B1 means there is some kind of other connection at the battery compared to that of theordinary BP18-12. I guess that's what they mean at "Terminal type" in the fact sheet.
These eight batteries will cost me 355 kr*8/6,8=$418, plus freight. Pretty cheap, I think.
Do you think this is a good choice?
Sorry about pestering you with questions all the time, but I am still such a newbie at this.
And sorry if the pictures become strange. They look a bit strange in the preview.
Gman
Gman's picture
Why not purchase the B&B Batteries EB SERIES for Mobility Wheel Chair, Scooter & Bicyclies?
I just purchased four EB12-12 locally for $122.56.
CSB also has a EVH 12150 12V 15AH Battery that the specs look good, but I don't know that much about there Batteries. Since they are also available locally, I might try out a set for a backup pack latter.
Peace Out,
Gman
Gman
jbird
These batteries are not as good as the EB20-12. The cycle life is at least 50% worse and the price they quoted you is quite high. The EB20-12 has a 50% DOD cycle rating of 800 while the BP18-12 only has 400. It only weighs 13.56 lbs compared to 14.22 lbs for the EB20-12 which is likely due to thicker lead plates that will probably hold up to EV usage(abuse) much better. Make sure that you get the bolt terminals and not the faston connectors. You can probably beat their price by alot on such a general purpose 18ah SLA battery online even after shipping on ebay (search rbc 11) or at vendors like batterygiant and still get a 1 or 2 year warranty. At that price the EB20-12 at places like electricrider, thunderstruck-ev, or batteryplex will cost only a little more than the BP18-12.
Gman
Gman's picture
B&B Batteries EB SERIES for Mobility Wheel Chair, Scooter & Bicycle Spec Sheets
I noticed that, but the EB20-12 would not fit in my under foot Battery Compartment.
Peace Out,
Gman
Gman
Starvid
The 12 Ah's I guess are to weak, and the 20 Ah's they didn't have in stock, and if I wanted them to order them for me that would take 12-14 weeks and I would have to order a minimum of 144 batteries. Quite a non-starter.
Starvid
Problem is finding a battery retailer when you are not living in the US of A. :?
BB also makes a "EVP" series which have exactly the same performance as the 'EB" series. They have been on the market longer and might be more available.
Any prospects of mail or internet ordering from a dealer elsewhere in the EU?
