XM-3500
321 posts / 0 new
Henry42
Re: XM-3500
I am not able to take it on the road until I get it licensed and insured, which will happen as soon as I get the paperwork to the DMV. I have to go about a mile before I have a relatively flat spot to ride. I plan on reporting on top speed on flat roads and climbing the hill. The hill is about 2/10 of a mile and about a 70 feet rise between the bottom and the top.
Here are the pictures. I have more, some with a tape measure as a guide.
Box under seat (11" x 8.5" X 6.5")
batteries in front of seat
batteries under seat (front part)
batteries under seat (rear part)
Circuit breaker
Battery charger (Sorry I forgot to remove the plastic cover)
Thanks, I never thought of a bag of groceries or the helmet.
I did not see a NHTSA sticker. On the plate with the VIN the statement is "THIS VEHICLE CONFORMS TO ALL APPLICABLE US FEDERAL MOTOR VEHICLE SAFETY STANDARDS IN EFFECT ON THE DATE OF MANUFACTURE SHOWN ABOVE."
The low bean shines about 85 feet and the high beam shines about 180 feet. The brake light is easily visable for 100 feet. It seems to have the same brightness as my car if I compensate for two versus one head, tail, and brake light. The small white light appears to be a parking light.
The battery charger does not have an on/off switch that I could see.
Thanks for the information about calling to get the MSO. I would have waited a long time before calling.
Last seen: 6 hours 52 min ago
Re: XM-3500
Thanks for showing us the pictures.
As I feared, the XM3500 doesn't seem to have any kind of BMS, or I'd be seeing wires coming from the battery interconnects.
At least it has those nice gray plastic covers over the battery connectors.
Curious what the charging voltage from that charger will be. Hopefully about 3.7 volts per cell. If you can find a measurement point for the pack voltage it would be nice. Measurements at as many individual cells as you can reach would be nice too.
Plan on installing a BMS. I will hopefully soon be testing a Gary Goodrum BMS on my pack and will report back.
eped
Re: XM-3500
I see it does not have the BMS wires as well. I wonder if Mountain Chen has any comment on this (or any of the dealers who may have direct factory contacts) as it is advertized quite clearly. I am also wondering now (although it has been commented not to make a huge difference) if the regen is enabled.
eped
Re: XM-3500
Actually looking at the pictures closer, there are some wires. It is possible they are using a segmented BMS where say X numbers of cells are in series per BMS leg. If the number of cells is 3 or 4 then adequate charging balance can be done with LiIon batteries (this is what is done in NB computers and there is not much of an issue). Going much beyond 4 cells in series though becomes a possible issue.
As a side note, SLA's are really a series string of cells so when you charge one battery, you are really charging a series string. However, when you have multiple batteries in series you need to charge balance each one due to having too many in series.
HalfMooner
Re: XM-3500
Henry, I want to add my appreciation for sharing your words and photos with us. Still, if I could have my druthers, I druther you'd sent the bike itself! Waiting's killing me.
wolf3510
wolf3510's picture
Re: XM-3500
nice pics...cant wait for your top speed report...
Re: XM-3500
Yeah, I was expecting a per cell BMS as well. I'll hopefully get to strip mine down this afternoon and see what I find. BMS was certainly promised (and I specifically asked both Chen and API - although I didn't ask about "per cell") - we'll see what the factory has delivered (hopefully Mountain Chen will provide input as well).
No regen on this bike either - in fact the brakes don't feel as strong as the XM-3000's. I suspect that's because this one has ABS. There IS enough stopping power it's just that the brakes feel softer and require more pull.
At the moment I feel like the bike is worth it (yes, I'm a vendor) - but there are a few areas I'd like to see some improvements. But remember - this is the first production version of this model - it's all about continuous improvement!
PetroZero
PetroZero's picture
Re: XM-3500
What about the ergonomics of the handlebar design and instrument cluster locations? It looks odd in the pics above (and all previous ones I've seen). The instruments appear to be behind and below the handlebar and obstructed from view without leaning forward to see over the handlebars. I believe that Vectrix has a similar layout, but the handlebars are designed to allow for this (they have a cutout "V" shape in the center column area which appears to facilitate the view without leaning...
Also, the instrument cluster appears to be too horizontal for my tastes, seems like it should be inclined to a more vertical orientation to read from the riding position. Of course, I've just seen pics and have not actually sat on the bike to confirm these assumptions. Perhaps they can be proved wrong...
~ scott
My Blog: <a href="http://www.petrozero.org">PetroZero.org</a>
My Bike: 2007 Lashout Electric Scooter (12mph/12miles)
Considering: xm-3500Li
electromotion
electromotion's picture
Re: XM-3500
Thanks for the pictures and first impressions. Still Waiting!
This is what the NHTSA is looking for on motorcycles/scooters, fresh off their site. I think if this imformation is on the plate with the VIN it is acceptable.
Gordon
Mikie
Re: XM-3500
Hey Kids, great to see the pictures, thanks so much Henry. I believe there is a BMS and it is
sitting on the side back wheel like on my Kasea 2000 and Mr. eped is probably correct in his assumption
that it is doing several+ cells at a time not individual ones.
I got a good kick out of Scott going on about the ergonomics of the display, please take no offense buddy I really appreciate all that you bring to this forum.
Lets remember two important basics here:
#1Credit to the Chinese for even doing this project, its about profit and there is a huge market here.
#2 We all know how the Chinese make their products, cheap and fast so lets not try to have our expectations to hight and look for anything other than a basic stripped down model that we all can and will improve on!
I would like to say that I am excited about where our collective progress will be in 12 months after we have had a fall, winter and spring to work out all the kinks and personally customize our own bikes. Thanks guys and John please send us pictures as you strip your bike down--bummer about the regen -see above for explanation....Mikie
mikie
Re: XM-3500
eped,
I have done one, and soon two, conversions to 40AH Thundersky cells, and simply balancing the cells in groups of four would not work very well. If it did, I could have just used powercheq balancers and saved a lot of annoyance (I have some for sale BTW). The six individual series connected cells in a lead acid batteries can be equalization charged through a deliberate overcharge at the end of charging - even SLA's to some extent - particularly by maintaining SLA batteries on float. This doesn't work with LiFePO4's.
Gary at the endless sphere forum got a request for a quote for multi-hundred unit lots of a 20-cell BMS from a Spanish electric scooter mfg probably doing import/upgrades of Chinese scooters. So, an assembled 20 cell BMS may become widely available and cheap - hopefully they won't ask for some kind of exclusive supplier agreement.
Mikie
Re: XM-3500
PJD--excellent info, thanks so much. While all of us are waiting I found this new addition to the eco scooter site on the inner workings of the acceleration of the Chinese bikes and how to get around their controls, enjoy; Mikie
MAKING A TURBO SCOOTER [POSTED 08/05/2008]
Recently a customer brought up a good point about a control box he was using for a replacement on his scooter. His scooter didn't seem to have the torque (acceleration) it had with the old control box and motor even though the new control box and motor were improved with higher wattage. Some control boxes have a ramp up feature which restricts the amperage output to under 40 amps automatically. So instead of putting a full blast of 100 amps to his motor for acceleration it only got a portion of the power of the batteries. This is a safety feature to keep scooters from wheeling. Electric motors will translate power very quickly and thus the design of control boxes to prevent accidents.
In the past he had placed a relay on a scooter that allowed him to throw a switch after he was going and make the motor wire directly to the batteries for acceleration and hill climbing. As an engineer he quickly came up with a safe circuit that would essentially do the same thing. The voltage that powered the relay would not be high enough until the scooter was moving fast enough to prevent a wheelie, and then with the press of a button on the handlebars the relay would kick in and zoom you to full speed and acceleration. So you could not press the Turbo Button while the scooter was still and energize the relay. Nice. But the power straight from the batteries was immediate and strong.
See his article and design on our performance article page:
http://www.scootersupport.com/performance.htm#TURBO.
For under a $100 a turbo circuit could make a slow feeble scooter strong and fast. It's worth looking into.
mikie
smace
Re: XM-3500
There is a section in this thread from John about a LiFePO BMS from
http://www.paktrakr.com/
That will handle a lot of batteries.
PetroZero
PetroZero's picture
Re: XM-3500
Hi Mikie, no offense taken, just an honest critique of what appears to be a cumbersome design. I I do believe in not letting the perfect be the enemy of the good. I'm well pleased that the Chinese have brought this bike to market and at a very affordable price point. It's availability should serve to foreshadow of what is to come in the next couple of years. We are approaching a tipping point in terms of EV's becoming the successor to the ICE (and that's a trend that I heartily support, as you might tell from my sig).
~ scott
Re: XM-3500
Hi smace,
The paktrakr is just a battery monitor not a battery management system. So, it will tell you if your cells are getting out of balance but it won't do anything to fix it...
I'm about to open up my XM-3500Li - pics to follow...
TANWare
Re: XM-3500
Coming from the world of RC flight and battery packs I have some experience with LiPo's. Balancers at the single cell leel there are requierd but that is because of two primary reasons. First off we love to hit the batteries with 10, 20 or even 30C drain rates. The second is we want them charged to the max in the minimum amount of time.
Draining at 1C to 0.5C allows the batteries to stay even much more easily. Also with RC we will drain them out to almost nothing. Opertunity charging of the scooters helps quite a bit here too. Lastly Lipo's take the first 90% of charge easily but the last 10% is the pain and can take as long as the first 10%. Since were are not charging at 1C the charger can be tuned to more evenly distribute the voltage accross the cells.
Now for a charger to be tuned to reasonably distribute accross 20+ cells we probably would need a 48 hour charger. at four cells an 8 to 10 hour charger should work great. This isn't to say that at about 50 or so 50% charges it wouldn't be nice to check on the individual cells to be safe.
Also oppertunity charging is key here. Don't run under 20% to be safe and personally I'd suggest to never run below 5% but 10% is safer. Then again 0% may be safe if the manufacturer already has a safety margin built in.
Personally I am disapointed though. I was sooooooo wanting on of these but if there isn't a top speed of 55 I can't use it. I wanted it primarily for my work commute of 8.5 miles one way. first mile is 35 mph, then 4 miles at 50 mph and then 3.5 miles at 40 mph.
mrladderman
mrladderman's picture
Re: XM-3500
what voltage is the controller on this xm-3500? can you add another battery pack to it. like the xm-3000...
MikeB
Re: XM-3500
John H,
If you can confirm that the VIN plate looks anything like the one electromotion posted a few posts up, then I'm probably ready to order one from ya. :)
Mike
eped
Re: XM-3500
MikeB - the VIN plate matches the format above. John H can confirm as well.
Mikie
Re: XM-3500
Hey Kids, things are heating up and we are all waiting on John.... TANWare-- my guess is that
the speed limit is governed and that with a simple operation we will be able to remove the governor and have the speed necessary to cruise the highway. Now that means us(meaning me) greedy bastards will have to watch our "gas tank" and not suck all that juice out and get caught with our pants (re:batteries) down....Mikie
mikie
Henry42
Re: XM-3500
The batteries are in sets of 4, there are 5 sets. It looks like there may be room for another pack in the very front if the foam padding is removed. It would be a tight fit, anyway I thought some additional pictures of the battery compartment might help.
and a picture of the rear wheel.
Here is page 16 from the manual, which describes using permanent magnets to recharge the batteries.
Here is a picture of the dash with me sitting it what I think will be my riding position.
The output from the charger is (according to the tag) 72.6 V @ 10 amps, I am charging it now to see where it quits charging.
The VIN tag looks like the NHTSA sample you uploaded.
davem
Re:..using permanent magnets to recharge the batteries.
You're a good man Henry !
COuld you elaborate on "using permanent magnets to recharge the batteries."?
vinnie
Re:..Paktrakr Li BMS
Earlier in the thread there was talk about the Paktrakr...Ken Hall, owner and developer of paktrakr lives near me and we email occasionally. He is developing a Li BMS system that is near completion, although he did not give me a precise date. I believe it is in testing now.
Vinnie
Broomfield, CO
sparc5
sparc5's picture
Last seen: 13 years 2 days ago
It just means that the motor is a generator/break depending on how the motor controller is configured. Any top speed on this scooter yet?
XM-3000...
-72V mod
Henry42
Re: XM-3500
The charger completed charging (red light turned green) and the cooling fan turned off at 69.5 volts. I did not time the charge, however, it has not been really used. (I have played with the lights etc.) Also I noticed that the charger is a Thundersky, however the manual is for a YMC Series charger.
The yellow button on the right hand control turns out to be another horn button. I guess I was not pressing it correctly. I pressed it again today and the horn sounded.
TANWare
Re: XM-3500
My fear here is they claim tested to 63 ungoverned. Even then they are probably talking indicated and then with the spedo supposedly being 10 mph off 53 would be top and at full drain. Since this was most likely obtained using topped off batteries then at 90% I'm sure 50 or lower will be the top. Not a good thing as then we'd need to see either a rewound motor or an extra battery set and a new charger along with a new controler too.
If the bike eventually delivers on its promise of 55 mph and even returns 30 mile range at a constant 50 mph it will have a major market impact. Especially with short milage commuters such as myself. While I realize the money will never be recovered as 4,000 buys 1000 gallons and even at 20 miles per gallon I would have to make 1176 trips back and fourth to work just to recoup the initial investment, so at least 5 years of 5 days a week. Now that isn't going to happen.
before gas went up I was using 24 gallons per week. I now use about 18 gallons of gas a week modifying my driving and conserving routs. With this I could save another 4 gallons or more a week in good weather. Now it isn't the money, I can more afford 24 gallons per week then drop 4 grand, I want to eventually go fossil fuel free and I am on my way.
Also placing money into a fossil fuel alternatives feeds the market. If history has taught us anything is that the corperations out there will follow the money.........
Re: XM-3500
Henry,
Did you count the number of cells? is it 19 or 20 cells? 69.5 volts is 3.66 volts per cell, which is just right for 19 cells - but to provide a full 60 volts (and obtain the advertised speed, i really should have 20 cells - but in this case the charger voltage is too low.
Also, I don't want to rain in the parade, but if the cells were installed in their factory condition, without an initial conditioning charge for each cell, and without a BMS, the cells are probably in wildly unbalanced condition - some may have had end-of-charge voltages of 4.5 volts, others at 3.5 volts. Only a few charge cycles in this condition will ruin some of the cells.
I know you probably find it aggravating that your scooter probably needs urgent service and modifications straight out of the crate, but that is the case with these Chinese products. As a first step, I would:
1. Label the cells with a number in sequence, from 1 to 19 (or 20), starting at the _negative_ end of the pack.
2. Rig a 16 to 18 gauge wire from each positive terminal on the cells, (an open-end type connector is convenient) plus the negative terminal of cell No. 1. Label each wire with the corresponding cell number, except the last wire which should be labeled "pack negative". Be very careful not to short anything - wrap tape around your wrenches.
3. Buy some kind of a 22 terminal junction block or connector which provides easy access with the probes of voltmeter, and rig these wires in sequence on the block or connector. Mount this someplace convenient under the seat. Label the terminals with the cell numbers.
You now have a convenient way to check the voltage of each cell. This will also be used as your wiring harness for your BMS when you get it.
For now, you can check the voltages or each cell. The voltage at 30% to 70% state of charge is not very sensitive to the state of charge - they all vary between 3.25 and 3.35 volts. instead, you will need to babysit the pack while it charges and look for the cells whose voltage accelerates ahead of the other cells, reaching 3.65 volts first, and for the cells that stay behind. You can then balance the pack as it is charging by discharging the high cells (using the junction block terminals) with a few 1157 auto bulbs soldered in parallel, and letting the low cells catch up. It is like playing "whack a mole". It also is only practical if the cells are just a few percent out of balance. If there is more imbalance than that then each cell should be individually charged to an equal level using a bench top power supply or other such regulated 3.65 to 3.7 volt power supply.
Re: XM-3500
TANware,
It is hard to believe that the scooter couldn't displace more driving. If you are using it for commuting, you can use it for most errands too. Add a givi trunk and you can carry a lot of stuff.
With the LiFePO4 pack, I can use use my e-max for practically everything from April through October. The car is just for out of town trips. I'm using an average about 12 gallons of gasoline a month.
Now, I live in a bit of an old fashioned place where I can get practically anywhere without having to get on a freeway or other fast 4-lane roadway. I didn't even need a scooter where I used to live - everything was a short pleasant walk or short bus hop away.
TANWare
Re: XM-3500
My problem there is a weekly weekend comute to PA to my moms house. I take care of her an the property there. That is 11-12 gallons there at 320 miles round trip. It was almost 15 gallons but I now leave early Saturday (4am) to avoid the traffic jams and stop and go getting there.
PetroZero
PetroZero's picture
Re: XM-3500
Henry, excellent post!!! Thanks for the pics! I especially appreciate the "rider's perspective" shot over the handlebars to the guages. From that shot, it does not appear to be as much of an issue as it would appear from the profile side photos we've seen.
Also, the manual appears (from what I can tell from your shot) to be well written. How many pages total? It might be helpful to take a shot of the TOC...
~ scott
Topic locked
  • stuuno
