XB-600 deep cycle battery?
2 posts / 0 new
laurierocs
laurierocs's picture
My uncle used to be an engineer at Cushman's(scooters) and he said that I have a "Deep cycle" battery and NOT to charge it every night. He said to charge it when it gets really low otherwise the battery will have a "Memory" and will hold that memory and will only use that much. I'm not sure I've explained that as well as he did.
For example:
If I ride for 15 minutes everyday and charge right afterwards...pretty soon I'll only have 15 minutes before the battery is drained.
Does this make sense to all of you?
Laurie(rocs)
mopedbrainy
Re: XB-600 deep cycle battery?
SLA (sealed lead acid) batteries hold no memory-for effective purpose.Charge yours ASAP & AOAP. If not discharged too low & they would last more than twice as much . Trickle charging would be even better
