HELP with Rad2Go Sunbird
2 posts / 0 new
lewmel
I just purchased a used Rad2Go Sunbird at a yard sale for one hundred dollars, and the previous owner said the bike worked fine about a year ago, but since then has lost the key. I took the ignition switch out to find out what part I needed, and now I can not find a 3 wire ignition switch that will fit. The only 3 wired ones are very small and do not have the black casing that is around the original switch. Can anyone tell me where to purchase the correct ignition.
Pames
Re: HELP with Rad2Go Sunbird
If you're still looking for this, here's a link. http://store.monsterscooterparts.com/igmokwike3wi.html
We got this ignition module (ours didn't come with a key either), and it seems to work just fine on ours. One caution, though: the face (the part with the keyhole!) is too small to fit in our hold in the body. We'll have to put duct tape around it, or something.
Also - the new keys (not surprisingly) do NOT open the locks in the storage/battery compartments on the body.
Oops...After re-reading your post, it sounds like this might be one you've already found (too small) but just in case...
Good luck!
PA
