hub motor wind turbine
I am trying to use my wilderness energy 36 volt hub motor as a wind generator but I don't know if i'm hooking it up wright. I have 3 wires comming out and no matter what combination I use I get AC voltage. Does any one know how I have to hook this to a rectifier to get DC voltage?
before comments
Comments
I knew I had to use a rectifier. About 2 months ago I used a rectifier out of a gm alternator and everything was o.k. but I'm not sure how I had everything hooked up. As I said, there are 3 wires comming out and they are all the same. No matter which of the 3 wires I use I have continuity and ac voltage. Where's my negative or common wire?
Am I missing somethig?
the 3 wires are three phase wired in delta.
they are *all* actives/lives. there is no common/neutral.
you need a 3-phase bridge rectifier.
this will be composed of 6 rectifier diodes (as oppposed to 4 for a single phase rectifier)
EDIT: wrong polarity in image fixed
Every thing is working fine. I was not spinning it fast enough.
mosesravoori's picture
Out put current can be charged to DC current?which is attached to electric scooter.
though yes this is possible, theres no point.
its a perpetual motion machine attempt, and will fail like all before it.
useful energy out is *always* less than useful energy in.
