Attachment | Size |
New wiring | 32.47 KB |
I would like to know if its possble to plug only the Motor and the wiring for the sensors, The speed adjust holder, the batteries (72v) and the power switch with the stock Controller with the shunt mod and the 72v mod ? Thanks
Yes it is. Although I would recommend still using the brake connector because without the motor brake you're going to have a difficult time stopping.
Cool ! I bought a Xb-500... well it's a copy of it. Its the same frame, lights, and the wiring is totally diffenrent. its a 36v controller, no DC-DC converter. totaly different in terms of wiring. I want to buy the xb 600 motor and controller with the 72v mod. and bypass the signals, lights, and all the other electric feature for now.
I have a ohter question.
Some peaple say its a diffren motor between the 500 and the 600. But xtreamscooters tells me its defferent. Is the motor will fit on the Xb-500? Is the sizes the same ?
Thanks again
Since you're essentially building a new scoot, the real question is what will fit in your frame.
What diameter is the wheel? What braking system (disk - drum)? What side? What rear fork arm width? What axle diameter?
Crucially, will the frame safely carry you at the speeds you will be generating?
The frame is 100% Xb-500. Only the wiring. The braking system is all drum too. Is the motor from the Xb-600 will fit ?
"Will an XB-600 motor fit?"
I don't know. When you say that your scoot is exactly like an XB-500, does that mean you have had the two scoots beside each other, or that it looks like XB-500 photos? The Chinese manufacturing system is big on subcontractors selling sub-assemblies and aggregators combining them into products, so there can be a lot more variation than you might at first expect.
I only own an XB-600 (and it really isn't fair to ask X-Treme for info on converting something they don't know about). The dimensions I listed seem like the critical ones to me. Please measure the space you have, and I will do the same tonight; the scoot's not with me at the moment.
Your right it's looks like the same. If it's not exactly the same tire and tube, i can just order an tire and the tube for the xb-600 motor. If the space is to wide or too small I'll change the metal part and solder with plasma solder a new metal frame. Of curse if the frame is the same size. It would be much much easer. I'll tell you the size between the bolts tonight. I'm at work too.
An XB-600 is:
No joke my copy of Xb-500 is
# Wheel 12x2.5
# Brake: Drum, left side
# Brake/anti-torque arm: Left side, 4 1/2" from axle
# Rear swing arm: 6 1/8" inside
# Axle dia: 3/8
All will fit :P
"vaya con Dios mi amigo"
The 3/8 axle is listed by X-Treme as an option, but I would advocate grinding the swing arm out and using the 5/8" one instead - it would be twice as strong.
Now, if they have one in stock...
Ya but yo say that is 5/8 but xtream as the choice of 1/2 or 3/8. How can i get a 5/8 ?
Since the real diameter is in millimeters, who knows? I got that dimension by holding a tape measure up to the end of the axle. I'd get the fattest axle they have.
I've just order the parts for the optomising of the scooter
XB-600 Tire
XB-600 Tube
Rear Tube XB600-131/XB600-131R
Motor / Rear Wheel
Hand Throttle
I've started to remove the old motor and the wiring. I would like some photos of the rear wheel of the Xb-600. Without the plastic frame. To see the torque arm and the bolts and everything... Thanks
I posted a message about securing the motor in http://visforvoltage.org/forum/4655-xb600-getting-rear-axle-tight#comment-39062
There's no torque arm, but the tabbed washers key into the swing arm and lock by the flats on the axle. They must fit very well - the tabs were too deep and held the outer washer off the swing arm on my scoot. There is a particular arrangement of the spacers on the brake (left) side. I can do some photos tonight (the plastic covers are LONG gone!), but I'm not ready to disassemble the wheel right now.
Mark
This is a bad news for me. Thanks for the drawing. I'll wait my parts to see and your photos to confirm my fears. Is the E-brake slow tne motor ? or is just a system to avoid trottle input when you brake ?
E-brake is dynamic braking. The right brake lever both
The left lever only inhibits controller power.
In addition, when coasting above 22 MPH, the controller/motor goes into regen mode, putting up to 400W back into the pack.
I've just called Miva. The compagnie behind extremscooter.biz. 3 of my 5 parts are back order. 2 to 3 weeks to receive all. I'm living in Montreal, Quebec, Canada, and the summer here is like 3 months. 2 is already past in rain and the rest...well... we'll see. While I wait, I'll redo the connections of the batteries. I have two 36 volt chargers so I'll put a switch to charge or to travel. It will give me time to buy the mosfets, the batteries (3 others cause the old bike was only 36v)and to do the baterie wiring. Really sorry for my english... I'm french.
Here a scan of my battery wiring.
AAAAAAAAright.
I've started to remove the motor and the old controller. So this is some photos :
This is the scooter before
This is the tiny little 350w motor
Motor
Removal of the motor
The place the others 2 batteries will fit
The scooter all unscrewed
Thebattery pack before
The battery pack after
This is the 2 jacks I'll use to charge the 2 36v
I'll acheve that in putting a switch for "charge mode" and "travel mode"
Update !!!!!!
My order was very too long so I canceled it and I will order (probely tomorow)a motor from Zhejiang Haoren Electromechanical Co., Ltd. You should there prices !!! 70kmph 1200w 60v With controller, tire, and throttle control handle for.... 170$(no shipping, to be confirm) !!! I'll order more parts to reduce the price a bit more. I have an old JiaJue that I want to rebuild too. Plus 1 of my co-worker want to buy the same thing and what to do the same mod. So an other price drop. :p Can't wait!
I'll update here more
Go see http://www.zjhaoren.com/egsjj.htm
OUCH !!!!
618 $ for the shipping ! OUCH !!!!The only way to have a reduction is to buy 20 sets ! His 20 person would like a 70km/h 60v 1200w all you need to convert you bike to a scooter?
Email me to galilee1986 [at] bell.net
Ouch !
Good ouch day !
Guizmo OUCH !
