Anybody know anything about "Electric Green Motors"?
__Tango
Hi folks.
I was looking for the zapino dealer in San Carlos, CA (electric green showroom) today, but stumbled across the website for "Electric Green Motors" (http://www.electricgreenmotors) and was wondering if anyone knows anything about them.
I haven't heard anything, and it looks interesting...or mysterious at least.
Thanks.
...tango...
frodus
frodus's picture
Re: Anybody know anything about "Electric Green Motors"?
____________
Travis Gintz
1986 Honda VFR Conversion
www.evfr.net
Last seen: 1 year 1 month ago
__Tango
Seems like a hoax
Odd. the site now says "have a great 2020" where the countdown used to be...and then it opens up a new window to send you to google.
geez...i hope i just didn't get phished in some way...
knabo
knabo's picture
Last seen: 5 years 1 week ago
Seems like a trick...
Andrew Dawson
Green Transportation Alternative - The Electric Bike
Hi Every Body,
How are you all? Though it's been a very huge problem, cars are still one of the most important necessity to be able to live in this fast-pace world. Not even the high prices of gasoline and other petroleum products, air pollution and its effects on everyone's health and accidents that killed almost millions everyday will make people stay away from their gas-guzzling, death machines that are their cars. Transportation is just a very important need that should be fulfilled and cars makes it easier for everyone.
But is it really that easy to own a car right now? After stating all the obvious downside of owning a car, there is still a long list of cons that is added to having to drive a car everyday. But obviously, we just can't stop driving cars and stay at home because that will just put lives to a screeching halt. But what if I tell you there are other ways to go about with your daily life, moving from one place to another, without having to turn that car key of yours? Well, there are. And one of them is using a electric bike.
The electric bike which uses lithium batteries can go at about twenty miles one hour in just one charge, depending on the load and riding habits. This type of two-wheel transportation are also almost completely silent, give off no emissions, do not use expensive oil, do not require to much room to operate or park, never need a tune up and provide exercise. So basically, it takes away almost all the drawbacks of using expensive transportation mode like cars at the same time giving more to oneself and the environment. Aside from those, using electric bikes is also efficient because people can weave traffic easily unlike their usual bulky cars.
Electric bicycles on the market today are a bit pricey. However, there is a way where anyone can own one without having to spend a fortune. They are called electric bicycle motor kits. These are kits that can turn your ordinary bike to a charged up electric version that has more kick than the usual pedal-power. Any bike with stable frame will do and can be converted into a futuristic transport mode.
Of course, the most important part of the electric bicycle motor kit is the motor, which is usually a hub motor. This type of motor is an electric one built directly into the hub of the front or rear wheel. An advantage to this design is that no additional transmission system is needed, thereby increasing the efficiency of the drive system. This design also does not require chains, belts or gears. Essentially the motor is the hub of the wheel and contains two concentric rings of opposing electromagnets. When power from the battery is applied to the motor the opposing magnetic force causes the wheel to spin. This type of motor is almost completely silent and requires no maintenance. The higher the wattage of the motor, the more power it provides.
However because electric motors are most efficient at high rates of revolution, this type of motor tends to be inefficient. Integrated planetary gear drive trains are sometimes included, but reintroduce transmission losses. Also, there are no standards for measuring wattage. Most hub motor marketers use peak output numbers as opposed to the operating output numbers, which means for example a motor rated at 1000 watts peak may be a 500-watt motor in its standard operating output. That is why purchasing hub motors can be a bit tricky at times.
An advice for people who wants to own an electric bike, e-Bikes that are built from electric bicycle motor kits are usually your best bet when it comes to performance, quality and savings. Building your own will actually give you an option to choose a more powerful motor, better battery, and many other features. Also, you get to choose which bike you can use as your foundation, be it your old bicycle that you've grown into or a much better bike than those factory-built e-Bikes in terms of weight and comfortability. A good electric bike motor kit should have the motor pre-built into a wheel, dual brake motor cutoff, a twist or thumb throttle, a motor controller, wiring harness and a battery mounting rack with a lock mechanism. One more tip is to buy a front wheel kit which is easier to install. A really good kit also includes wiring diagrams, mounting hardware, wire ties and complete step-by-step instructions for the installation. Lastly, purchase your electric bicycle motor kit from a company with good customer support because you would want to be able to call them if ever you have trouble putting up your electric bike. Anyone that can ride a bicycle can ride an electric bike and anyone with basic tool skills can install an electric bike conversion kit.
Electric bicycle is definitely the green transportation that everyone have been looking for. It can provide a very efficient alternative to the cars and trucks we have today. And at the same time, it also helps lessen air pollution and our dependence on fossil fuels. Also, using electric bicycles also give you a little exercise while going about your daily life. Many pros to this very simple solution. True, it won't solve all of our problems in just a day, but it's a good start.
Best Regards........
packaging usa
