X-Treme XB-600
3 posts / 0 new
Gman
Gman's picture
X-Treme XB-600
X-Treme XB-600
Model#: X-Tremeā„¢ XB-600
Colors:
Shipping: Included (Free)
Availability: In stock
MSRP: $799.00
Product Specifications:
Power:
Electric
Watts:
600 Watt
Motor Type :
Brushless Hub Motor - Motor is in center of rear wheel
Maximum Riders :
Can ride 2 people at once
Amps:
48 Amp Circuit
Volts:
48 Volts
Batteries:
4 - 12 volt 20 AMP (Four batteries total) (48 Volts)
Tire Size:
16" x 3" on Aluminum Wheels
Charger:
Smart Charger Included
Tool Kit:
Included
Speed:
20+ mph* using motor power only - faster if you also pedal
Distance:
Up to 20 - 25 miles per charge - can still pedal if charge is lost
Throttle Type:
Variable speed control - Twist throttle
Key Start:
Yes
Seat Kit Included:
Yes
Storage Areas :
Large area below seat + Large trunk + Small area near key
Braking System:
Front and Rear brakes
Drive System:
Rear Hub Motor (No Chains or belts) Motor is in rear rim.
Foldable:
No
Head Light:
Yes
Tail Light:
Yes
Brake Light:
Yes
Blinkers:
Yes
Measurements
Wheel to wheel 60" - Max Width 25" - Seat Height 33 1/2"
Carton Size (LxWxH):
65"x19"x38"
Scooter In Box Weight:
184 Lbs/with pallet 206 Lbs
Scooter Weight:
135 Lbs
Electric Horn:
Yes
Spring Loaded Seat:
Yes
Speedometer:
Yes
Battery Indicator:
Yes
Cargo Rack:
Included
ArcticFox
ArcticFox's picture
Re: X-Treme XB-600
The XB-600? That is SO last month. ;)
Posted info in "Dealer Deals" the same night X-Treme's webmaster was uploading it. LOL How's that for fresh?
www.BaseStationZero.com
gushar
Re: X-Treme XB-600
And here's my XB-600 purchased via ArticFox/BaseStationZero. Good scooter, good price...and thanks to AF for driveway delivery without the extra $70!
Gushar
Gus
