350 watt brushless hub motor.. where to get transistors to fix em?
3 posts / 0 new
edumejia13
Hi, I have a small e scooter shop in Colombia, south america. Some of mi customers have damaged their engines and I want to know how to fix them . I noticed some small transistors inside the engines. I believe this is the problem. where to find these transistor? Here in colombia I havenĀ“t been able to find them. Is there a shop in where I can order them by mail .. the correct ones.. how to know ?
thanks for your attention
Re: 350 watt brushless hub motor.. where to get transistors ...
Welcome to the forum!
It would be most helpful if you take some photos of the scooters and the motors and the "transistors".
We do also need a more detailed description to help you.
If you have working and broken scooters available to compare, then we should be able to figure it out!
edumejia13
thanks mik, you can see the scooters at my website www.greenflagelectric.com
unter "tecnologia" you can see a picture of the inside of the engine. I will post some pics of the transistors soon for the forum
ed
