Electricmoto Blade is getting another upgrade to 72 volts. Electric Supermoto racer
Roadrashhurts
Roadrashhurts's picture
Well the Blade is apart once again. It seems that every time I get it together and running I know I can still do more to get better performance. So apart it goes again. This time is to upgrade to 72 volts , new brake assemblies, plug braking ,tires and much more. Want to compete in the 200cc and under class at our local Supermoto track. I will keep you posted.
Roadrashhurts
Re: Electricmoto Blade upgrade to 72v. Electric Supermoto racer
Here is a pic of the new front 6 piston caliper and 225mm full float rotor.
Rear 205mm sawtooth rotor with 6 piston caliper.
Micro switch installed on rear brake lever for braking contactor control.
Roadrashhurts
Hope to have the brake contactor and coil resister installed tonight. Will add pictures shortly
Jabari
Jabari's picture
That's a very nice looking bike, about how much have you put into it?
Roadrashhurts
I can't say for sure what I have in the bike so far. I has to be in and around $5500 ++++++++++++. Every time I have it together and running, it's apart the next week to make it a little quicker with a higher top speed. I am now in the 55-60mph range. Having problems stopping now. Too much of one causes more problems in another. Hope this will be the last mods in a while.
