Rear bearings
Stanzeman
Rear bearings
Hello there.
Just wondering if somebody could help me with the rear bearings specs
I just had the bike tested (MOT) and they found some play in the rear wheel. The guy told me that the bearing is dead.
There are 2 bearings (ontside and inside). I have already changed the outside one while repairing the gearbox (dims:30x62x16mm). I now need to replace the larger one and I do not have its dimensions.
If somebody has this info handy, it would save me from taking the whole thing appart and wait until the replacement bearing gets delivered to be able to ride my beloved Vectrix again!
vectrixcr
Re: Rear bearings
Stanzeman
Re: Rear bearings
Grazie Mille!
Thank you for making my life easier!
Re: Rear bearings
Hello there.
worn rear bearings? how many km have you done?
Stanzeman
Re: Rear bearings
10K. I suspect the previous owner to have fiddled with the gearbox as I had to fix it shortly after purchasing the scooter. Maybe that what damaged the bearing. I did hear from other owners that they've had worn bearings as well. I ordered an expensive SKF replacement one. Let's hope it will last longer!
Re: Rear bearings
I have added this to the "Vectrix Collaborative Handbook", please stay on topic!
Which bearing did you use for the outside rear wheel bearing?
