Zapino 2008 Scooter
Submitted by baker mckonly on Sun, 06/05/2011 - 04:41
I just got a new 2008 Zapino scooter and it is giving me trouble. The problem is when you accelorate it starts to go and then stopps running if you let off the throtle you can start again and it does the same thing. Any suggestions
- baker mckonly's blog
- Persival
- boomingheight
- janet
- Bengun
- Skyhawk 57
Comments
Re: Zapino 2008 Scooter
umm you say new but your also saying 2008
I had a problem ware the cable for break was getting pinched
and when I used the throttle the regenertive part was activated
which made the motor stop working
once I moved the cable to ware it needed to be that fixed the problem
do you get up to full speed ?
on the E-bike I got there is a button for slow and fast speed
dose it happen on either setting ?
things to look at hope it's one of those
my only other guess is throttle or computer or the motor
the throttle cheap to replace but it might be a simple wire problem with it
the other two cost a bit more ergo the motor being the most expensive
I hope one of my simple idea's fixes the problem
as I just found out on the web
yours is gas not electric
so that changes ware the problem would be
one or two of my thoughts may carry over
but this means it's more of mechanical problem
it could be it's not getting enough air
or enough gas
which will mess up the mixture
causing it to cut out
also the posobilty there is water in the gas
or the gas is old and needs to be replaced
or things get too warm
so it blocked lines
if oil is part of it then it should be changed
things to look at and a bit easier to fix then the electric bike I have
