Problem installing Diagnostic Software.
3 posts / 0 new
Domi422
Domi422's picture
I finally got my Vectrix back from repair and was willing to try The Laird's modificated program. But I encounter a problem with the diagnostic software that refuses to recognise my peak pcbus.
I followed the procedure described and I'm sur my pcbus works as I can use the other programs delivered whith it. I did other and other but can't get it flashing with the diagnostic software...
If someone who had the same difficulties and have find the cure can help, it would be great.
Thanks for the help
Jonathanm
Re: Problem installing Diagnostic Software.
Hi Dominique,
I had the same problem - the problem is the driver. You will see the information here:
http://visforvoltage.org/forum/11662-problem-can-bus-usb-resolved
I am in France: if you want you can call me on 0607934210 - je parle francais...
Bonne courage...
Jonathan
Domi422
Domi422's picture
Great! Problem solved. As my Vectrix is charging, I will do the work tomorrow.
Thanks a lot Jonathanm. Maybe your post should be quoted with the others in Mik's message, it might help someone else.
Merci pour l'aide.
A second The Laird's modified Vectrix in France soon. May be you should sell stickers, a way to pay you back and advertise your excellent work The Laird.
