Rear Brake Rotor Bolt, M10x1.5x16 needed
3 posts / 0 new
HarryS
Replacing the rear tyre left me with a broken rear rotor bolt. Fortunately I was able to remove the broken one. Seem to be unable to find a replacement through the usual channels. Anyone who can offer a lead?
mobilemike4
Re: Rear Brake Rotor Bolt, M10x1.5x16 needed
This is just a metric bolt. M10 x1.5mm pitch or coarse thread x length of 16mm. You should be able to get this at an auto part store.
http://www.carrlane.com/catalog/index.cfm/29425071F0B221118070C1C513906103E0B05543B0B012009083C3B285357474A2D020609090C0015312A3...
This site explains metric ansi and sae.
For Live answers from my mobile:
Follow me on twitter @mobilemike4
http://twitcasting.tv/ PC version
Mobile version
https://market.android.com/details?id=com.sidefeed.TCLive
https://market.android.com/details?id=com.sidefeed.TCViewer
Last seen: 5 days 19 hours ago
M10 x 1.5 is is just the common standard coarse-thread 10mm bolt - also called just "M10". Make sure you get the same or higher grade number e.g "8.8", "9.8", "10.9". Your local hardware store (or whatever you call them in the UK) can help.
