Cause of low speed, R light flashing, odometer needle flickering?
15 posts / 0 new
VisFORvictory
Hi - do you know the answer to this - the Regen failed slightly as I was slowing to a T junction. Then the bike kept losing power down to a few mph (after each stop, I switched off and then on to see if it would self-correct, but to no avail). Even though it was showing 6 bars, the bike would go no further. The bike seemed capable of small amounts of forward movement (a few miles an hour). The fan whirred hard and the temperature light came on. There were a few unusual noises from inside. The orange R flashed on and off and the speed dial hand kept flickering up and down slightly.
It still does this...The orange R flashed on and off and the speed dial hand kept flickering up and down slightly.
Any views on the cause and solution?
Best regards,
Jeff
Re: Cause of low speed, R light flashing, odometer needle ...
I think you better stop riding it for now....
Hi Jeff,
your motor controller is most likely dead, the below will help work out in what way
if you are able to lift your back wheel off the ground, and do the following:
turn the key off
while holding the right brake and the throttle at full, turn the key on
that will put the bike into a diagnostic mode - the rear wheel should turn slowly smoothly in a forward direction
if it does not, try the above procedure with the left brake instead of the right brake
regards,
VisFORvictory
Matt, I followed your instructions and this does not happen..."the rear wheel should turn slowly smoothly in a forward direction". It also did not work with the left brake. The wheel twitches a little but does not turn. The spanner light comes on. So how does this affect the diagnosis and solution? Many thanks. Jeff
it means your motor controller is dead
basically starting with the right brake sets the motor controller to slowly rotate the wheel, without the use of the position encoder and a few other things.
as it cannot do this, there fault is in the controller.
you will need to remove the controller to do more testing
As a matter of practicality I do have a spare I can sell you, but your's may yet be repairable
VisFORvictory
Thanks so much!
So does that mean the encoder is not the cause (I was about to pay for a new encoder to be fitted)?
What further tests can be done after removing the controller?
Are you suggesting there might be other fault(s)? How can they be detected?
Sorry for all the questions. I have no technical knowledge (I only have an expensive bike that I cannot use!).
Many thanks!
Best regards,
Jeff
VisFORvictory
Thanks for your helpful advice!
So the encoder is not the problem (I was just about to pay for a new encoder to be fitted!)?
What further tests can be done after removing the controller - and what are the solutions?
Are you suggesting that there might be other faults (not just the controller)?
Sorry for all the questions. I have no technical knowledge (I only have an expensive dead Vectrix!). Many thanks!
Best regards,
Jeff
Archi13
Archi13's picture
Hello Jeff,
I think that you can try to reload the Mc program with scooterdiag if you can do it in using Peak USB-to-CAN adapter.
Best regard.
VisFORvictory
Sorry, I have no technical knowledge. Do you mean to re-load the software?
Archi13
Archi13's picture
Yes, but you need software and equipment and off course knowledge, if one neighbor can help you? Where you are?
The encoder is not the issue - the rotating wheel test you did earlier confirmed this
you will need to do a visual inspection of the controller - mainly the 3 phase terminals, positive and negative.
Take a picture of those terminals
if they are fine we can look at testing the IGBT with a multimeter.
but easy stuff first.
If you haven't already, look up my video showing how to dis-assemble to gain access to the controller
the software being wrong is a bit of a long shot, and hard/time consuming to test
VisFORvictory
Bedford, UK.
Archi13
Archi13's picture
Very long way for me, Marseille in France...
VisFORvictory
Please send me a link to the video you mention - thank you. Jeff
Last seen: 1 year 2 weeks ago
I am not antiscab, but simply insert his nick into the Youtube search box, and his very own channel will come up at the top of list ;-)
