Battery and kick stand connector is off
2 posts / 0 new
uws101
My five batteries measure:
6.6, 9.8, 10, 9.5, and 7.6 Volts.
What would be my cheapest fix? I do NOT have a dump charger. I bought one at Walmart - 6.6 volt one (not bulged) and it sooner goes to "maintenance" from "charging" - it shows 7.1v now. But some other batteries have bulged.
Secondly, you know the kick stand for the Zapinoo (not the double legged stand) - there is a washer styled connector that has come off. How exactly I should be putting it back?
uws101
Re: Battery and kick stand connector is off
Photo below of the kickstand from someone else's post.
You can see this wire just above the bolt.
Also unrelated matter - I see a switch marked "I O II" - it was behind the plastic cover - what is it for?
What position it should be?
