Scooter Diagnostics For Dummies
4 posts / 0 new
oobflyer
oobflyer's picture
Hello,
I'm reaching out for help with the Scooter Diagnostics program. If someone would take pity on me and help with a very basic, step-by-step instructions on how to run this application I would very much appreciate it.
I have the program, and I have used it many times, but as a Mac user I'm baffled how the Windows programs tend to lose their association with the required components (drivers, etc.) - is it necessary to assemble all of the components together each time the program is run?
When I clicked on the scooterdiag.exe application today I got the error message that the libmysql.dll file was missing, so I found it and placed in the same folder with the .exe file.
Then the error message came: PCAN_USB.dll file is missing - so I found it and placed in the same folder with the .exe file.
So now I have these items all in the same folder:
But, now when I click on the .exe file I get this error message:
I think I'm cursed with an allergy to Windows...
How would you recommend to get this program to work?
Details: I'm running Windows 8.1 on my Mac using the Parallels program. This setup worked just a month ago when I installed the latest firmware modification from the Laird.
Archi13
Archi13's picture
Re: Scooter Diagnostics For Dummies
Hello oobflyer,
it's better that you copy all dll file on the windows/system32 directory.
And plug and pray.
Last seen: 1 month 1 day ago
If You keep using this scooterdiag with your Vectrix I asure you,ll finally brick it!
File assciations do not disapear. This happening due to some kind of data/registry corrruption.
I suggest you buy and old, cheap but robust laptop like IBM T61 or lenovo T500 and use the scooterdiag installer to install the program correctly in that laptop.
oobflyer
oobflyer's picture
I finally got it working, but not without help. My son was in town and helped me. I don't know what I did wrong, but everything was on the hard drive - just not in the right folders. My son found the driver and moved it to the right folder and it worked. I connected to the Vectrix and installed the latest firmware (Thanks Laird!)
Thanks for your suggestions.
