Hi everyone,
I am looking into the feasability of fitting a 32amp fast charger to my Leaf battery powered Vectrix. Has anyone done this already ? Has anyone got any usefull information to get me started ?
Any help would be greatly appreciated.
Allan
Onboard fast charger anyone ?
Thu, 11/16/2017 - 03:09
#1
- Mohammadawawdy
- Jiya
- volejbol
- Gordongadget
- Cold Rider
Hi allanbairstow,
Check this: http://www.shop.vectrixparts.com/category/batteries-battery-charger
Hi, does your battery is lead acid battery? what is the battery voltage and capacity?
Fast charger you need is fan cooling or waterproof?
http://www.topbikekit.com/charger-c-70.html
you can check it if there have some charger you need?
Hi there, thanks for the reply and the link to the site. I am not sure which charger I would need but my battery is made up of 19 Nissan Leaf Li-ion batteries to give me 158v 60Ah. I am looking to charge it at 32amp if possible. Do you have anything that would suit those specifications ?
@allanbairstow,
Are you aware of this option ?
http://www.shop.vectrixparts.com/6-6kw-pfc-battery-charger.html
The 6,6Kw option from vectrix will integrate perfectly into your canbus system. it is your best choice
Thats really interesting, I assume a software upgrade would be need ? I will investigate further.
