Hub motor rotation
Hello every one. I'm new to this forum so please tell me if I'm asking this question in the wrong place.
When installing a GEARED front hub motor that has no markings or directions is there a specific that it should run? I just purchased a 250W DC Permanent Magnet Brushless Geared Motor. It's sold as a QQ- m100 or m100 or sometimes a Cute 100. It uses a small no name controller. The controller wire identification chart does mention reversing 2 of the Hall sensor wires if it runs the wrong way. I installed it with the wires coming out of the L/S of the hub. (from seat) This is my first geared motor so It's running in the direction I thought it should which is that it free wheels with zero resistance when spun forward & has a very minor gear drag when spun in reverse. Is this correct? It runs fine but I want to be sure I have not overlooked something since it does seem to have 1 possible problem. The possible problem is when using it full throttle for more than about 10 seconds it stays on (cruse control)untill you blip the throttle. The controller does have a connector that is for cruise control but I have not connected it. This bike will be for re-sale & I want to be sure everything is correct. This is not a mechanical (sticking) issue. Did I mention this came from China? They have only the most basic understanding of English & asking them did not shed light on anything.
PS. I'll have an article on this installation on my web page ezgo-now.com
I bought one SUNWIN 60v 800w (ALIEXPRESS) with same feature .The push button is convenient 'cause throtle requires full twist and down to 0 to snap out of mode.Three times better and less expensive . Enjoy . The problem is that binging too many to chew it for you then the stuff becomes increasingly expensive .
