This is probably a "well duh!" topic..
Has anyone noticed that when the kill switch is activated and you pull the left brake lever a few times and hold it, the gauge lights flash, all the LCDs are turned on and the speedo pegs out, then it sometimes goes completely blank and dark... then after a few seconds resumes normally? Like it's doing a reset?
This happens on my '08 bike, but not on my '07.
Scotter
My bike did that too before I had The Lairds software. There is a thread on this forum on it and XVectrix could reproduce the fault but I never found the root cause. I suspected humidity on the temp sensors because in dry weather it would not occur.
Found the thread: http://visforvoltage.org/forum/12158-sudden-electrical-gremlin
