Heated grips DIY
11 replies [Last post]
drgrin
drgrin's picture
Last fall I've fitted heated grips to my VX. If anyone interested I can put DIY here.
martinwinlow
Re: Heated grips DIY
First off, can we have a picture or two, source, cost and some specs? But I think it would be worth doing a write-up anyway, myself. MW
Regards, Martin Winlow
Herts UK
evalbum.com/2092
zeuz
I'm also interested in reading a DYI...
Also interested....
zeuz
I'm interested in fitting the Tecno Globe Gold heated grips, because they have the switch integrated to the grip, which I consider a plus:
Tecno Globe Gold Heated Grips
Could they be connected "directly" to an active power source ?
Or should they be connected to an auxiliary 12v battery ?
Could this auxiliary battery be charged with the traction battery, like in a Nissan Leaf ? (hence avoiding connecting an extra charger)
jasmim
I'm very interested. Please post DIY. Thanks!
Vectrix Vx1 Li+ 60Ah
jasmim
Please, post DIY, winter is coming...
jasmim
Finally I installed heated grips on my Vectrix Li+
Oxford heated gripes for scooters.
Cut up the old handles with a screwdriver to take off the handlebar.
I decided to put the switch on the handlebar cover in a discrete position.
Placing the LED power indicator . Green = low temperature. Red = high temperature.
Pass the wiring for the steering column
And binds to the wires that connect the low lights
Storage all cabling
Minimum Temperature = green light
Maximum Temperature = rede light
BLUESTREAK
REALLY nice job.thanks.
Nice J!
If nobody posts it, DIY! Wonderful work, congratulations.
You have powered them with low beam wire system, haven't you? How many wh do they consume? Were they expensive?
jasmim
R wrote:
Nice J!
Thanks. Yes it's powered whith low beam wire. With high beam wire system my Vectrix have a light into glove box :)
I don't know how many wh they consume. Sorry. I Paid 48 eur.
Sacko
A slight bump :/
A quick glance on the specs and they pull roughly 4amps, can the low beam wiring handle that current?
style="display:block"
data-ad-client="ca-pub-2401070691062219"
data-ad-slot="2079401426"
data-ad-format="auto">
  • joseb007
  • haji
  • thedudeisnotin
  • ebikeguru
  • Bonnie Zhong
Customize This
