Bottled Lightning: Superbatteries, Electric Cars, and the New Lithium Economy Essential to understanding the economic importance of lithium batteries
Where is the brake fluid checked?
2 replies [Last post]
Tanner's picture
My manual says to check the gauge on the left handlebar to ensure that the brake fluid is above the indicated level. I don't see it. If anyone has checked their Zapino's brake fluid level please help me out here.
Steve Tanner
Re: Where is the brake fluid checked?
There should be a little, typically rectangular, fluid reservoir/master cylinder near the fulcrum of the brake lever. If the scooter has a handlebar fairing, it is probably behind the fairing, so you will have to remove the fairing.
With the reservoir exposed, you will see a little sight-glass. The fluid level should be even wit the sight-glass.
Tanner's picture
Thanks. Apparently I have to take off the fairing to see it.
Steve Tanner
Short URL
Customize This
