54 Tooth, 8mm pitch Sprocket Needed
electricgreg
electricgreg's picture
Help!
I'm trying to find a 54 tooth sprocket (plus or minus a couple of teeth) that uses a 8mm chain. It was stock on my Panterra 500W scooter but I can't seem to find a replacement anywhere, only a 44 tooth which is too small.
I tried partsforscooters.com and electricscooterparts.com and monsterscooterparts.com. No luck.. any advice??
Jeffkay
Jeffkay's picture
Re: 54 Tooth, 8mm pitch Sprocket Needed
Try tnc scooters. Look at electric parts. Consider the 60 tooth. It has 4 bolt pattern.
Jeff K.
I think I found your part.
54 Tooth Rear Sprocket For 8mm Chain
5-1/2" OD, 1-1/4" ID. 6 bolt mounting pattern.
Item # SPR-854
You will need to scroll about 3/4 of the way down the page.
Grandpa Chas S.
electricgreg
Thanks Chas, but I didn't mention I need the sprocket to be 4 bolt pattern, 2 1/8 ID to fit over the freewheel. I don't even think the SPR-854 is modifiable - there isnt enough meat to oversize machine the ID.
electricgreg
Ok, I just found the exact part I need on tncscooters.com!
