razor mini chopper throttle pinout
1 post / 0 new
ejonesss
today i got ahold of an old razor mini chopper that someone had thrown out and i salvaged the electric parts controller,motor,throttle and wiring. (all electrics worked when i connected 24 volts to them so i know the throttle works)
the batteries are dead (0 volts) so i will be turning the batteries into a local battery recycler.
i was wondering if the throttles being 4 wires and has the battery indicator built in if they are 5k pot or hall based?
i think i can be able to save money by using the throttle with the kollmorgen motor.
i connected the multimeter to the throttle and got no change in resistance so i dont know if if may be hall based or if electronics can emulate variable resistor controls .
if you have worked with or know anything about them is there a pinout i can check with?
