Tilting Electric Tricycle
What's the biggest problem with normal trikes? Getting around corners! New Electric Tilting Trike, using patented tilt technology! When you lean or any sudden change of direction is made, the front section of the bike tilts but the rear wheels remain on the ground flat and stable! At just 30Kg the trike is very lightweight for a trike using a compact Lithium battery pack located below the large rear basket.
Tyre: front 20" x 2.15 + rear 16" x 2.15
Battery: 36V/10Ah Lithium-ion battery
Motor: 250W BLDC
Brake: Front V-type brake + Shimano rear roller brake system
Control system: electronic regulating system
Max.Load Capacity: 120kg
Net weight: 30kg
Range Per Charge: about >45km
Climb gradient: about 6 degree
Charger: smart charger
Max.Speed: 25km/h
Transmission type: axle and double chain transmission
Drive system: front wheel drive (Pedal Assisted System+Throttle)
Light: head light with meter + tail light
Brake lever: Aluminum brake lever+ switch
Balance Device: Yes (Anti-swerve device)
Gear System:Shimano Nexus 3 inter hub gear (Optional)
