I'm having trouble sourcing parts.
I'm having trouble sourcing parts and electronic components (individual transistors, diodes, etc...) for a coupe of projects I'm planning on doing. I know what I need in terms of tolerances and capabilities (Amps/Volts), but not the call/product numbers needed to properly find a source online. Does anyone know of a database that lists call numbers in relation to the tolerances of the electronic component they represent. Any help would be appreciated, Thank you.
Have you tried places like Digikey.com, Newark.com or Jameco.com? They can do parametric searches for many components.
Thankyou for your response. I'm sorry if I sound dense, but I've never head the term "parametric" before (and yes, I have a full 12th grade education). So I looked it up and (as far as I could figure) it means to search within a set of parameters, about what I need, so over the last couple days I've tried incorporating the word in my searches for an online component database, unfortunately to no result. I'm thinking that I merely may not be recognizing it when seen, or I may be simply doing it wrong. I know I should be able to find this on my own, but It's just not happening. The closest I've come is several links to e-mailing someone describing what I need, then waiting for a response (if they think what I'm doing is worth their time and my money to respond to). What I want is a free of charge database of components, and their matching product call numbers and specifications; all of which should, by all right, be common/public knowledge and therefore freely available. Once I have a call number for a component suitably matching the specifications I need for my project, then I can use that call number to, quite easily, find a suitable online supplier for said product. At the risk of me sounding lazy, would you (or anyone) be willing to provide a URL for a parametric search engine or database, or a step by step instructions for finding one on a specific website. Thankyou.
With a hammer, a chisle can be made. With a hammer and chistle, files can be made. With hammer, chisle, and file anything else can be made.
