NiMH problems with heat
1 post / 0 new
MitchJi
Forgive me if this information is already available here. I think this informationhelps explain some of the problems people are having. BTW does the Vectrix Charger use heat to terminate the charge or a hard voltage cutoff?
http://endless-sphere.com/forums/viewtopic.php?f=14&t=20547&p=302104#p302104
You're correct on the 1.0v per cell minimum, any lower and the risk of cell reversal grows.
You can do that but, the chargers you have will use a rise in pack temperature for charge termination. Then you want the pack to cool down before using. Using them when too warm decreases performance and shortens life.
As the packs degrade, their internal resistance increases. This causes more heat which causes more internal resistance. You want to stay out of this cycle of degrading performance by --not asking more of the packs than they can do while not getting too warm. IN ADDITION, CHARGING THE PACKS MAKES THEM GET WARM-- DONT USE THEM TILL THEY COOL OFF. its not a safety issue but rather a pack longevity issue.
A buddy in california uses a MONSTER NIMH pack and only charges at home at night, so the Pack is cool in the morning, has enough AH (24v 40ah I think) to go all day with no charging. Pack has lasted 7 years.
