scary looking seam on my BD36 wheel
12 posts / 0 new
needWheels
Last seen: 15 years 9 hours ago
I don't recall ever being able to see the seam where a 26" wheel is joined together.
I noticed this after seeing some strange marks on the side of the wheel which I now believe are rubber from the brake after scraping against the seam and tearing a little bit.
How dangerous is this? :(
LinkOfHyrule
LinkOfHyrule's picture
Re: scary looking seam on my BD36 wheel
It's nothin', methinks. Both my WE rims have that join, too.
needWheels
What's actually holding the wheel together then at high RPM, other than the pull of the spokes into the hub?
needWheels
Oh and what should I used to remove that "bur" on the side which is cutting into my brakes? Sandpaper?
dogman
dogman's picture
Some fine sandpaper wrapped around a block should deburr it fine. Some folks do relace the hub on to good rims, I admit to looking at the seam whenever I do a preride inspection. One thing about having a pilots licence, I now am even more obsessive compulsive.
andys
andys's picture
I'd replace those poorly made single wall rims with some Rhino-lite or Mavic double wall ones. That's one of the drawbacks of the WE kits-really funky rims.
LinkOfHyrule
The rim will be fine at high rpm. It's a decent join, if not pretty. A little sandpaper work could get rid of it.
And I could have swore these were double wall? I don't have any more lying around so I can't tell right now. :/
dogman
dogman's picture
I haven't heard of one falling apart yet, but staying straight, wellll....
andys
andys's picture
they are single wall, and are way more prone to going out of round than a double wall rim. Forget going off curbs. For some reason, single wall rims are also more likely to have ugly looking welds like that, which catch the brake pads funny and make the brakes pulse under light braking. Crystalite gives you a double wall rim, but not WE.
needWheels
If I had the budget to replace the rim I wouldn't be buying just the BD36 ;)
I can't even justify getting the wheel trued for $15+tax, I am going to try it myself and hope I don't make it worse (and then ironically need to spend more than $15+tax but oh well)
dogman
dogman's picture
Don't sweat it. Like you, I have the WE stuff since the aim is to save money in the long run. You will get good at wheel truing soon enough. My second WE hub came really loose. Suspension helps. After I take some pix today I'll be posting on how to modify the cheap steel shock forks to fit a WE hub. Got a new one to play with at a gargage sale. Nearly unridden $150 mongoose bike for $40. This one looks to have more strength in the frame at the seatpost. Now I have a parts store on the old bike.
silentguy
My WE BL 36 rim had the same problem or worse,
it has a small gap.
I took some proactive measures, and epoxied the gap,
so it doesnt separate further.
Hopefully that will hold up.
See pics below.
