Gear noise revisited
Last seen: 1 month 1 day ago
I know this is a redundant problem: 2 gearboxes were replaced without success, and only an entire swing arm replacement with a well calibrated engine could solve solve my gearbox noise. But after 10.000 km my new gearbox is getting noisy again... After reading some gearbox topics I couldn't find a clear solution to reduce that ugly noise. The vectrix rear panels behave like a cage amplifier due to its concave geometry. Some noise absorbent placed behind this panels could prevent some noise to get to the rider, but it would be more intelligent to solve the problem that causes the noise...
Anybody found a way to reduce the gearbox noise? many thanks.
Re: Gear noise revisited
Eyeinthesky has done some dampening of sorts, but I do not know how exactly.
The most important point is to be certain that the noise is not a symptom of something nasty that needs attention!
And sounds are oh-so-hard to describe!
richard_durant
richard_durant's picture
Last seen: 10 years 4 weeks ago
The problem is that the gear teeth are inexplicably straight cut, making this "car going in reverse" noise ... The only plausible explanation for this is to make the Vectrix noisy enough to warn pedestrians. What a pity for people like me used to drive perfectly silent electric vehicles !
Richard.
"We don't inherit the Earth from our ancestors, we borrow it from our children." - Antoine de Saint-Exupery.
straight cut gears are more efficient, cheaper to make, stronger, lighter and more reliable than the helical cut gears found in most cars and bikes.
its the first reason why straight cut gears are used in *every* vehicle where economy was the highest priority (vectrix, impact, ev1,iMEiV, etc).
oobflyer
oobflyer's picture
I must admit I had no idea that there were gears on the Vectrix! Where are they? I thought the hub-motor configuration eliminated the need for gears!
There's a plantary gear. There are no gears, planetary gear is only used for ratio between high speed RPMs of the electric motor to the RPMs of the wheel.
