25-36 volts
Pedego Comfort Cruiser Blue with Balloon upgrade.
Submitted by Pedego on Thu, 01/28/2010 - 20:27
As the name implies, form and function are combined to provide a cool looking electric bike that is comfortable to ride to work, running errands, getting exercise, or just having fun.
All models blend fashionable retro-cruiser style with high quality electric components to carry you quickly and easily to wherever you want to go. How far will you go?
Motor Brushless Gearless Hub Motor on Rear wheel
Power 500 Watt
Gears & Speeds 6 Speed Shimano Gears
Batteries Lightweight Lithium in a Removable Pack
Shifter Shimano SIS Index® Shifter
Charger Smart Charger Included
Amps 10 AMP Hour
Volts 36 Volt
Tires Kenda 26" x 2.30" K-RAD Urban Tires
Speed 20 MPH using motor power only
Distance 15 - 30 miles per charge(depending on rider weight & terrain)
Throttle Type Twist Throttle Variable Speed Control
Frame Type 6061 Light Weight Aluminum
Handlebars Cruiser Style with Promax Stem
Braking System Avid BB-7 Front Disc Brakes and Dia-Compe Rear Hub Brake
Drive System Rear Hub Motor (Motor is in rear wheel)
Measurements Wheel to Wheel -35" W-13" H-39"
Seat Padded Adjustable Seat Height 33" to 39"
Bell Standard
Battery Indicator On Handlebars
Warranty 1 Year
Foldable Electric Tricycle
Submitted by ecoway on Wed, 08/19/2009 - 06:40This special tricycle incorporates innovative design with practical daily use, and it features two wheels in front and one in rear; the front two springs will adjust and balance the rider when turn around corner or any sudden changes of the direction is made.this trike can be folded to fit into the car trunk or van.
this triycle is very fun and easy to go ! Keep in mind, we only used high quality parts putting all our bikes together and dedicated to become number one manufacturer in the field of ebikes and tricycles in the world .
- 2 comments
- 245 reads
Oxygen Emate electric bike, electric bicycle, ebike
Submitted by yendrek3 on Tue, 05/12/2009 - 00:44Hi I Own my wonderful Electric bike. It's made by Oxygen Bicycles and I just love it. It's a 36V motor with lithium ion battery, takes me everywhere in London. The one I bought is Oxygen Emate Explorer Got is at the good price for the quality. If anyone looks for an electric bike then I can recommend this one. I had it for the past 12 months and the only thing I had to do is to change the brake pads and recharge the battery. Definitely good value bike for money.
MOEPED 6
Submitted by DGoncz on Thu, 10/09/2008 - 04:20More later: search Google "MOEPED" for all versions
Boyd's Cycle
Submitted by boydculver on Wed, 06/11/2008 - 08:47This is the second prototype I have built with the same parts. Unfortunatley, the more I learn the more I see what I've done wrong. The relatively small motor I have had trouble turning that wide tire. So I am starting a more carefully researched motorcycle with the same parts. My new plan is going to stay as light weight as it can be.
Electra/Voy/Scoot 'n' Go Phantom 4
Submitted by arthurpage on Fri, 06/06/2008 - 17:32- 3 comments
- 2205 reads
