brake switch
steamboat
brake switch
I have a E-trike(dual front wheels) with a foot brake that cuts off the motor when the brake is applied. My problem is, I stop going up a hill, when I start again, I let off the brake, the trike starts to roll backwards, I twist the throttle and the trike jumps. I am afraid it may cause me to tip over. I have seen this feature on other controllers, does anyone know why this feature exists? Is there any reason why I shouldn't bypass it?. Thanks in advance. Jim
goodnslo
throttle disable
Some throttles have the inadvertant ability to fail all the way 'on'. With the stop disabling the throttle at the controller then this is a safety to prevent an accident or maybe disabling the throttle all together. Since you did not describe the throttle, as in what make and type- resistor or potentiometer nor the wiring layout, it is difficult to help so whatever info you can find would make it easier to recommend a possible solution.
Ray_T
Ray_T's picture
"parking " brake
it might be possible to add a second brake that isn't tied in to the controller for holding on a hill.
Fechter
Fechter's picture
You can disable most brake
You can disable most brake switches by simply disconnecting the wires. The idea is that in a panic, applying the brakes will automatically kill the throttle. If you know how to ride, this feature is really not necessary.
Some kind of kill switch is a good idea to prevent runaway in the event of a throttle or controller failure. A main battery disconnect relay is the best.
steamboat
Thanks for your response.
Thanks for your response. It is a thumb operated 5K potentiometer throttle on a Taiwan trike without a wiring diagram, only an owners manual. Your answer about the throttle failing makes sense . I think mopeds and motorcycles have a kill switch on the handlebars. Hmmm Jim
steamboat
Thanks, see first response.
Thanks, see first response. Jim
