Chapter Seven: The Blast is a blast (first test ride)
The good weather and my curiosity got the better of me and I just had to give the Blast a test after getting the motor mounted and the drive chain sized. Went out and attached the throttle, slapped on the battery and put the rest of the controls in a plastic shopping bag hung from the handlebars. Figured I should try it before I took it in to get the new Albatross bars installed and fitted with cabling. Man, it was quite an enjoyable experience to finally try it under power.
The performance was better than I expected from that little motor and I am pleased with the decision to purchase this kit. However a few more issues popped up, no surprises there though.
1. The controller / headlight won't fit on the center of my bars due to interference with the stem clamp.
One more thing to buy, a Minoura space grip will get it mounted on center.
2. My car top bike rack rear clamp won't fit around the Continental fat boy 2.10 x 26 Town and Country tires.
I wanted a hitch and hitch mount bike rack anyway so one of those will be in my future.
3. The headlight came with a cracked lens.
Allan says he'll ship another but wants me to finish the installation and see if anything else needs replacing and he'll ship it all at once. Due I'm sure to the long distance postal rates from Oz to the US. Thanks Allan, good customer support is what I like.
4. The battery charger wouldn't charge the battery pack.
Looked closer at it and there is a switch that switches it from 115 to 240 volts. Took the back off of the charger and flipped the switch to 115. Replaced the back and it charged up the pack no problem.
I just got back from dropping off the Blast at Revolution Cycles, the LBS, and it should be ready to pick up on Wednesday the 31st along with the space bar. Yippie.
Short list of issues this post. The finish line is in sight and we'll be good to go by Spring including upgrades.
I just can't bring myself to use the supplied plastic brake levers and give up my Avid single digits. I'll have to work up a usable substitution as this will be used in Vancouver Canada from time to time and brake cut outs are required. Electric bikes are more common up there and some of the Politi know what to look for. Last time I was riding up there the Coppers had a roadblock set up on the bike lane and they were writing tickets for the helmetless riders. The cage drivers were whizzing along well above the speed limit, no roadblock for them though. Go figure........
Allan also sent me a basic digital camera to help with the posting of pictures.
A technical question has been sent a couple of times to the powers that be here but no answer yet. Can anyone tell me if I can delete the files from the upload area without having them disappear from my previous posts or do we have the 500 kb limit in total?????
- Sturdly's blog
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
Comments
sounds fun, Be curious to
sounds fun,
Be curious to know the top speed on level ground, no wind.
RE: technical question
Sturdly,
First allow me to congratulate you on your maiden ride, sounds great! I hope you have many more rides and thanks for all the great information you have shared with the community.
To answer your technical question; If you delete any of the images in your file area which have been used in a previous post the post will loose the images in it. So far you have only used 92.38 KB of the 5000 KB of file space you are allowed. At the rate you are using file space you have room for about 159 more images. I don't think you are in danger of running out of space soon. Please leave the images you have uploaded in your file area.
The average jpg file used on the forum is about 40KB, so each member has room for about 125 images.
ILBCNU,
VisforVoltage
Moderator, Captain
Chas S.
Moderator Team Captain
One more thing
Thanks for the clarification Captain. A new issue has popped up though. The attach images option seems to be missing from where it once was down below on the page, did you move that or is there some incompatibility issue with my version of Safari ?
So am I
So am I Nick, however that number may take a while to get.
You see in Seattle where I ride elevation changes from about 75 feet to 550 feet above sea level. There are few long flat places that are available for that kind of test. Which is also one of the main reasons for my choice of a bottom bracket drive over a hub motor, gear selection.
I will post it when I find out though.
Missing Link
Sturdly,
I don't know about Safari so I am not sure if there is a problem with that browser. I have checked the site with Internet Explorer and Mozilla Firefox and both of these browsers work fine. The Link has not been moved.
If this continues to be a problem please contact the site Webmaster.
ILBCNU,
VisforVoltage
Moderator, Captain
Chas S.
It was my browser
I finally gave up on trying to get the 4 year old version of the Safari browser to work with this site and downloaded the Firefox. Low and behold all the prompts and controls appear. Posting pictures will once again be possible and more will finally follow.
Thanks for the tip Captain.
RE: It was my browser
Sturdly,
You might want to view our new Help Tutorials to learn the easy way to post, upload, and insert images to your post. It only takes about 5 minutes to view. More Tutorials are in the process of being built but this is the first.
ILBCNU,
VisforVoltage
Moderator, Captain
Chas S.
