Moderator Testing 09 - Blog
2 posts / 0 new
Board Moderator
Board Moderator's picture
How to modd a RazorPB200 into a 45-60mph monster
Stock Razor specs:
24volts7amphours cells
30amp controler
200watt motor 11t/65t gears
5 wire twist grip
run time is about 45min to 1 hour
top speed 18mph down a hill, lol
this is a stock RazorPB200
this is it taking on cones!
stock razor doing wheelies
Stage #1.
36volt upgrade:
36v7ah or 12ah cells
40-50amp controler recomended
3 wire twist grip recomended
200watt motor 11t/65t gears(motor is now 250-300watts after you upgrade to 36v)
Run time is 30min to 2 hours (depends on what size cells you use)
Top speed 26-28mph no problem!
cones much faster
1st speed test
2nd try no faring 27mph
new bike cam mount.....realy cool!
Stage #2
Upgrades:
500w36 volt motor(custom motor mount required)
50amp 36v controler
still use of 11/65t gears(speed is slower couse of that, ordered new set that week)
test run through the grave yard, lol GP racing
3rd speed test still slow with 11t/65 gears
4th speed test, my speedo is now failing. had to get a new one(use of 18t/65 gears)
fly by #2, i know no helmet, but this was when i had no road rash yet...tops out over 30mph nearing 36mph
Maple wood park
WARNING: The content on this video may contain potentially offensive language, and may not be suitable for all ages.
chain is almost totally fatigued! gears are popping
a run down of the whole ride
Fly by #3 lol no helmet agen, dont raz me about it! 0ver 40mph
Fly by #4, while my drunken friends wach lol 40+mph
Stage #3
RazorPB200 into my Ex-Volt1500z bike
Upgrades: 48 volts
48v@100-150amp controler required
48v12ah cells
1500w china motor 18-28t/65 gears
run time 30min-1.5 hours depends on riding style
top speed: over 60mph no problem!
fully reworked frame to handle the cells and heavy motor
curb weight:70-85 pounds heavy, dont pick her up too fast!
stock to modded bikes
day 5 into a Ex-volt1500z
day 6, bike is fully done!
In house wheelie at take off!
full speed tire expansion
ILBCNU
Re: Moderator Testing 09 - Blog
I hope this test post has not been edited and approved because it still has BIG problems.
ILBCNU
Moderator Captain
Chas S.
Moderator Team Captain
