test paragraphs
2 posts / 0 new
andrew
andrew's picture
test paragraphs
testing adding paragraph space
should be 2 P spaces after this
test
Any idea how to add more than one new line space?
ILBCNU
Re: test paragraphs
Andrew,
You need to turn the paragraph marker on add the non breaking space command then turn the paragraph marker off like this -  . Now just go to the next line and start a new paragraph.
There are 2 lines after this line.
This line is 2 lines down from the previous line.
Here is another example;
This is line 1.
This is line 4.
Lines 2 and 3 are skipped because of the code.
The above example looks like;
This is line 1.
This is line 4.
ILBCNU
V is for Voltage
Moderator Captain
Chas S.
Moderator Team Captain
