Controller Thoughts and Questions ...
28 posts / 0 new
MB-1-E
MB-1-E's picture
Last seen: 16 years 6 days ago
I purchased a Navitas 100-36 controller for my mountain bike conversion. It's rated at 30A continuous and 100A max. It has "current and thermal limiting the unit is fully protected".
Used for: 24V 650W Scott (3/4hp) Permenant Magnet DC Motor rated at 30A.
I don't know what my actual load is with a 10:1 ratio or with the 12.68:1 ratio that I plan on changing it to. (there are just too many variables, weight, temperature, friction, hills etc)
The Navitas controller fried the other day.
I emailed the retailer about it and they said that before they issue me an RMA# they need to know the specifics of my drive system.
I emailed back with the information and a general electrical and mechanical schematic of my system.
I'm not very happy with my original choice, I thought it would work well for this conversion. Perhaps I was wrong.
I'm looking at alternatives. If they warranty it fine, I'll baby it and hope it holds up but it sounds like no matter what, I'll eventually need to get another, higher amperage, controller. It's a bummer, the one above cost me $150.
Curtis and Alltrax controllers come to mind but I wonder why there are so many rebuilt Curtis's if they are so good. It probably has to do with using contacts which arc and deteriorate after repeated starts and stops.
I don't know anything about Alltrax other than some of you have them.
I looked at some Curtis and some Alltrax controllers but it looks like I would need to go to a 200A. They sure are spendy!
Any suggestions on a good controller that has a Great warranty? I want one that is definately not going to fry, hopefully it's not going to run me more than $175-$250.
Would something like this work with a 24V system?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230138653859
Thanks for any info that might help.
Re: Controller Thoughts and Questions ...
I myself am fond of 4QD controllers (http://www.4qd.co.uk/) but they don't really have one for 200A load. And their 120A controller is over $200.
MB-1-E
MB-1-E's picture
Hi Gman,
Well, they have a 24-36 200A for only 200UK (but that's $400) just a tad more than I was willing to consider. Plus shipping, of course ... :)
A good non-programmable 180-300A is likely where I'll end up. I've been finding some pretty good deals on the Alltrax but will keep my eyes open for what's available.
Besides cost, what's the downside of getting a controller that is rated higher than I think I might need? Is it more likely to hurt my motor? (at 24V)
Is going to 36V a lot easier on the controller?
(Probably not recommended for my 24V Scott motor though)
I don't think I could possibly fry a 300A but a 200A would probably work fine under the harshest conditions. In that range, the price doesn't seem to be a lot higher for a 300A.
Dave
MB-1-E
Icon Photo of lighning striking Eiffel Tower Jun 3, 1902, taken by MG Loppe'
Dave B
MB-1-E
echuckj5
echuckj5's picture
Dave,
I share your disappointment. I have been following your posts the last few days. I have been to busy with work. I make wrought iron outdoor furniture and I am in "season".
Let's break the current "amp" issue down. "And please, anyone out there, put your 2 cents in if I am wrong".
The motor is 80% efficient. Thats about 30 amps. Without doing the math, on a flat road, no acceleration, 18 to 20 mph, with the motor very close to its design rpm the motor will be drawing 30 amps. Up a decent long grade, maybe 5%, the motor will be drawing 50 amps, but, it is no longer in its efficient range, probably 60% effiecent. Probably closer to using 80 amps. IF the motor is not near its peak rpm it will use all the amps you supply it.
I use the alltrax controller npx 200 amps non programable. I chose this controller because it does not spark when it is switched on. This sparking slowly destroys contactors. On the curtis controllers you supply the controller a "pre-current" bypassing the contactor with a wire from the battery to the controller that has an inline resistor. I did not want any current drain, no matter how small, so I chose the alltrax.
Ken at KTA services sent a letter with my purchase of motor and controller that no one makes a reliable controller that is sized right for the scott motors. In this letter Ken felt a 60 amp controller would be ideal. Ken also, on a phone conversation, strongly advised me not to volt this motor at 36 volts.
I am using odyssey batteries. I can supply over 2000 amps for 5 seconds, over 1000 amps for a minute. My fuse is rated at 180 amps. On a cold very windy day. I climbed a long 1/4 mile grade, I am guessing about 4% at 20 mph, 9.6 to 1 ratio, 40 mph headwind and blew my 180 amp fuse.
Now that it is summer, my motor gets very hot, I can hold my hand on it only for a few seconds, it will burn you. I am really guessing here, probably more than 125 degrees and not more than 150 degrees F. My controller, absolutely no increase in temperature. The controller has no heatsink. I do need a method to control current. Fechtor has designed current limiting into some controllers, I will probably start working on limiting my current to save my motor .
So it seems my controller is oversized and very reliable. My motor has been performing well, I do worry about the magnets in the motor weakening. I only have about 2000 road miles of experience behind me.
Well, thats all for now Dave,
chuck
[b]AGM BATTERIES[/b]
echuckj5
echuckj5's picture
Dave,
I just reread my last post. When I said I had only 2000 miles of road experience, let me expand a little.
All of my riding is on streets. Both to and from work I have to climb a long grade that slows me down from 26 mph to about 21 mph, then a couple of short very steep grades with, of course, stop signs. I am not 2 careful when it comes to throttle usage. In 2000 miles I have had one flat, and one blown fuse. I am going a little faster lately, I don't know why, about 27 mph on the flats. I don't charge my batteries properly, I use a 24 volt solneil charger and am using four batteries and connect the charger to charge all the batteries at once. By the book, 400 discharges at 15 miles a discharge should mean my battery pack will last about 6000 miles. I thought my problem would be with the batteries. It looks like, after 2000 miles, heat is going to degrade my motor. My batteries seem to be better than when new. I don't think this is a temperature issue in the batteries, they are always inside and are only outside for the 20 minute ride to work. They might be 10 degrees max warmer than in the winter. I should change that sprocket to a 13 tooth for a 10.5 to 1 ratio, but, I will get more chain noise doing that. This is the main reason I hav'nt changed that sprocket is that the chain was silent when I had a 15 tooth, the 14 tooth is, I don't know how to describe this, is bending the chain just a little bit more which causes a whirring sound.
chuck
MB-1-E
MB-1-E's picture
Thanks Chuck,
That does give me some perspective on what may be required for the Scott motors (even though mine is a 3/4hp rather than your 1hp)
I think our motors may be pulling a similar load due to a lot of battery, jackshaft assemblies, driver weight etc.
If I go to a larger ratio of 12:1 but on more hilly terrain and figure out some limiting to protect the motor I should be ok as long as the controller is going to hold out.
Maybe when you get a chance, you could show me where you have your 180A fuse within your system.
I might want to go with a 135A (due to differing motor sizes and carry a couple along).
Sounds like I really nead a 180A controller (can't seem to find one) but a 200A should definately do the trick.
Why do I feel like I'm walking on a tightrope here? :D
Thanks for your input Chuck!
Dave
MB-1-E
Dave B
MB-1-E
Board Moderator
Board Moderator's picture
EV Controller Collaborative Hand Books are in the works, we just need to figure out how many Hand Books are needed for the various type of EV Controllers.
Any suggestions on how many we should start with?
Regards,
Board Moderator
Cheers,
Board Moderator
MB-1-E
MB-1-E's picture
That could be very helpful information!
As I learn more, I'll do what I can to share any information that I garner about controllers.
IMO, it would make sense to group controllers with the various types of vehicles. (i.e. Motorcycles and Large Scooters, Bicycles and Pedelecs, Small Scooters and Pocket Bikes, Cars and Trucks, Karts and Boards etc)
Then again, perhaps a breakdown by motor size and type of load would also work well since many of the applications tend to overlap some.
I know that I've had a rough time finding the right balance of load/ controller/ motor that should work well for a specific application. Maybe a kind of spreadsheet or matrix from light use to heavier applications and suggested controller types based on motor size ranges.
I know I looked and could not find a controller review. I got the impression that there are favored brands but selecting one sure depends on a lot of variables.
As for a specific number of controller types, I don't really know what is available.
... sorry, just thinking out loud (maybe even rambling on ... :D )
Dave
MB-1-E
Dave B
MB-1-E
Board Moderator
Thanks, good idea. We'll probably start with E Bike Controllers, since that seems to be where the most inquiries are located, and link it to Building E-Bikes Collaborative Hand Books rather than lump them all together.
Regards,
Board Moderator
Cheers,
Board Moderator
MB-1-E
MB-1-E's picture
Sounds great!
I have no doubt that it will help us "Shade Tree EV Builders" a great deal.
Update on my Navitas Controller situation:
Electric Vehicles USA, Inc. (the retailer) has responded to my email (and requested schematic that I sent them) and said that they'd like to send me an "advandced replacement controller".
Sounds like they are being very supportive and standing behind their product.
As you can imagine, I'm quite releaved.
Dave
MB-1-E
Dave B
MB-1-E
Board Moderator
E Bike Controller Collaborative Hand Books is ready, we just need to do a intro about E Bike Controllers etc.
Just need to Add child page.
Regards,
Board Moderator
Cheers,
Board Moderator
echuckj5
echuckj5's picture
Dave,
Hope I'm not making you feel like your on a tightrope with my writing style. I try to get as much in as I can before my keyboard locks up on this forum. I think it is a motherboard issue, just not ready to buy another computer when usually it happens just here. My dad is degreed mechanical, electrical, hydraulic and degreed in electronic controls. My dad can make me feel like I am on a tightrope. He is retired, still answers the phone, "Johnson". I have worked around him for all of my life and he just assumes I know what he is talking about. I learned a lot from him, and from 2 1/2 years of physics in college. I never liked electricity 25 years ago when it came up during my studies, I learned enough to pass the tests. I liked hydraulics and thermodynamics, earthmovers and big engines. Wish now I had studied more, the electrical elements that I was forced to learn dealt a lot with electric motor design.
Any how,
Both the Bidwell book and Ken at KTA services put the fuse just before the main on/off switch, "contactor", between the battery pack positive and the contactor.
So, battery pack + cable attaches to the fuse, the fuse attaches to the contactor, the contactor cable then goes to the battery + on the controller. This is confusing, I just don't know how Chas Stevenson draws a diagram. Hopefully he will draw it for you.
I hope you can get over that tightrope feeling and get back on the bike.
chuck
MB-1-E
MB-1-E's picture
Hi Chuck,
Niether you nor your writing style my friend are the cause of my acrobatic-imbalance. ;)
The "tightrope" is finding the right balance between getting as much juice from the batteries to the motor as possible ... without supplying too much or frying something in between.
With your help, the help of others and Google I'm beginning to get a small grasp on some of it.
Your description of fuse placement makes perfect sense and no diagram is necessary.
I gather from your 180A fuse with a 200A controller that the fuse is located there to fry before the controller does.
Is that a slow blow fuse of some sort to allow for some surge during initial startup?
Since it appears that I'll be getting another 100A controller as a replacement, I'm considering a means of keeping the controller cool when I'm not going fast enough to force moving air over the built-in heatsink.
I'm definately going to add the heatsink that Sturdly gave me although I'm not sure how much surface area will make contact with the Navitas.
I do know right where this one overheated, so that helps me know where additional cooling could help.
I do have a small Delta 37 cfm 12V cooling fan that I could put a switch or thermistor on that I might add, it draws 0.48A but wouldn't be on most of the time. (It's a high powered CPU cooling fan)
I seriously doubt that it would make a heck of a lot of difference though.
I know the most effective way to avoid trouble is to design the system so that it never overheats.
I think I'm probably making this more difficult than it needs to be ... but it took a fried controller to learn my lesson. :)
Thanks once again for your words of wisdom Chuck!
Physics has always been my favorite subject, for sure. My modest education in electrical/ electronics stems from my Army days as a generator mechanic, I always did a bit better in things of mechanical nature.
Dave
MB-1-E
Dave B
MB-1-E
echuckj5
echuckj5's picture
Dave,
I guess I should start my own blog. Main reasons that I have not. My computer skills are weak. Converting files is a real task for me, ie posting photograghs. To make a drawing and posting I found to be impossible. I used to have a program called coral draw which would convert any cad drawing into code to run machine tools using xyz axis or into jpeg images. It was a breeze to use. When I use my kodak camera to take pictures its own software steals them, I think it is kind of a default issue, whatever opens the pictures first hoards them. If I use different software to open my kodak pictures I loose clarity, kodak must be putting a little code in the image that makes it better to use kodaks proprietory software. Kodak pics are tooo big to post. So, I use image shack to re-size. I like things to be plug and play.
My fuse does not have a delay, it will blow at 180 amps. My alltrax controller is not programable. The npx 4834 has a built in ramp up to limit current, ie, acceleration. I can feel this ramp up from a stop. I twist my throttle fully, I accelerate nicely, then at about 10 mph I can feel a good increase in power as the controller gives out more current. I went on the alltrax site, they list all of the data for their atx line, but nothing for the npx. The atx series are programable, I have not looked at their site in months, but, I am pretty sure limiting current is programable. Ramp up is definitely programable. If you investigate their website it should answer all of your questions on their controllers. In fact, I am going to relook there now.
chuck
Board Moderator
echuckj5,
No problem on the Computer skills, help is available from your world wide Moderator Team.
If you are planning to use images, all we need you to do is upload them to http://visforvoltage.org/user/65/imce , and we'll insert them where you want them for you. (Example: Insert 1stbikevc3.jpg here) You can also send them directly to us at moderator_team [at] visforvoltage.org
You can also contact one of your Moderator Team Captains to set up something.
If you share the knowledge, we'll provide all the necessary Computer skills.
Regards,
Board Moderator
Cheers,
Board Moderator
Chuck,
The VisforVoltage Forum will resize the photos for you when you upload them so they are the correct size for posting. Please give it a try, we would love to see some pictures.
Chas S.
My Bicycle Pages
tortuga0303
tortuga0303's picture
Last seen: 18 years 2 weeks ago
You asked earlier if there was a drawback to getting a controller that was too big. I am not completely sure how the controllers you are buying are set up, but I do know that in order to overcome the capacitance of the gate in the power driving mosfets, a driver circuit of suitible size must be used. If too small a driver, it will take a bit longer to activate the base threshold energy, and the mosfet will not be able to swich on and off as quickly. For a 200 amp controller, this could be as much as 6 amps of power to drive the mosfet! So the bigger the controller, the more power it takes to run. This is a little intuitive, but useful none the less. I gues I would just figure out what your max energy usage will be (motor at stall is an extreem case) and have a good safety margin.
Wont catch me ridin dirty
MB-1-E
MB-1-E's picture
Thanks Tortuga,
I figured that this was true but I didn't have anything to really base it on, so your explanation does help.
It appears that for now, I will be using the same 100A Navitas controller since the retailer is going to warranty it.
I realize that you don't have the specifics of this particular controller but ...
Can you recommend any methods that may help lessen the chance that I will overload this replacement?
Do you think a fuse placed between the batteries and the contoller will help if it is rated less than the controller maximum rating?
What about a fuse between the controller and the motor? Or both?
What about additional cooling (a fan) to disipate heat from the sink, do you think this is a wasted effort since an overload situation would tend to happen rapidly rather than over a long time span?
I will be changing my reduction ratio from 10:1 to 12.68:1 which should help lessen the load on the system.
In retrospect, I think the controller did cut out but kept working when I backed off the throttle slightly. I now know that I should have just stopped. An awareness of the controller will help in the future.
Dave
MB-1-E
Dave B
MB-1-E
tortuga0303
Well.....I am no electrical engineer, But I do have an engineering degree and love to tinker around (so feel free to correct me anybody that knows more than I do, and I am sure there are plenty) so here goes my advice based on your questions as far as what I know.
"Do you think a fuse placed between the batteries and the contoller will help if it is rated less than the controller maximum rating?
What about a fuse between the controller and the motor? Or both?"
There are two main systems within your setup. There is the PWM (pulse width modulation) system that runs at farily low amprage, and there is the power system running from the mosfets to the motor (with the battery as a supply of course). Both of these systems are running in parallel to each other. BUT...Each system alone has the main components running in series, which means that the amprage across each component (especially in the power mosfet section which is of the most concern) will be virtually the same. This means that the amprage at the battery to the controller will be roughly the same as the controller to the motor, will roughly be the same as the amprage from the motor back to the battery. (This will not be exact due to the driver circuit, temp control and other power drawing sub circuits, but these will be small).
SO...theoretically it does not matter where you put the fuse in these parts of the circuit, because if the power is high in one part, it will simultaniously be high in the other parts as well. BUT...and isnt there always a but???...many controllers use a large capacitor to smoth out the PWM square wave, so that it isnt so "sharp" between on an off cycles. This means a slight delay between power delivered from the battery through the controller to the motor. So high amp draw goes fromt he battery, charges up the capacitor (this is an example of a power spike) and the capacitor levels it to an avarage power, and then a bit later delivers it to the motor (not sure if there is an acutal delay, however the point is that there is no voltage spike that is very severe). Your sensitive piece of equipment is the controller, so you probably want to protect between the battery and the controller. Im sure though that putting a fuse between will be redundant, but its not going to hurt anything.
"What about additional cooling (a fan) to disipate heat from the sink, do you think this is a wasted effort since an overload situation would tend to happen rapidly rather than over a long time span?"
the overload may be a quick occurance within the circuittry of the controller, howeve if you have a really beefy one, it could be a slow process that builds up heat in the motor. My advice would be, dont take chances, heatsink everything, more than you think you need. The cooler the system runs the longer the component life, and the less chance of a blow out.
"I will be changing my reduction ratio from 10:1 to 12.68:1 which should help lessen the load on the system."
As you probably know, power, is amprage times voltage. or in motor terms, torque times speed. So changing the gearing ration does nothing, a ration of 2:1 with 10 amps and 10 volts is the same as a ratio of 1:2 with 10 amps with 10 volts ( 10 x 20 is the same as 20 x 10) so gear ratio doesnt really matter that much. However remember that when it comes to betteries, more voltage and less amp hours will go further than high amps and lower voltage.
Again, I could be mistake on alot of this and would value input. but I hope this helps.
MB-1-E
MB-1-E's picture
Thanks again Tortuga,
It all helps. I'll keep 'er cool and add a fuse for sure.
I asked the retailer that is sending a replacement if there is a chance that I can upgrade to another controller.
I don't know what his perspective on this will be but it sounds like a controller with a higher continuous amp rating might be better for this build.
What I was getting at with the change in ratio is to keep the motor from ever getting to a stall.
I was under the impression that at a stall, the motor would likely do more harm than while running at a more efficient rpm. Just want to avoid the "worst case scenerio".
Dave
MB-1-E
Dave B
MB-1-E
tortuga0303
Yea, you got it right, at stall the motor is stops transfering energy into kennetic motion, and begins to act like a large resistor, with low impedance, you can figure out how much power it will want to draw using homs law. Test the resistance of the motor you will use... and use the formula Voltage = amprage x resistance, solve for amprage (as you know your voltage) and you will find out exactly how much amps your motor will draw at stall full throtle. But yes, a lower gearing ratio will help against stalls...and take your top speed down a notch proportionally to the ratio. This can be good and bad, In flat areas, you are getting alot of torque but that same energy might be better used for top speed (there will be a sweet spot where your torque, rpms your weight and wind and rolling resistance all balance out to give you maximum efficiency). But in your case, protection from hills sounds important.....of course you could always do what I do up hills.......pedal.
echuckj5
echuckj5's picture
Dave,
Went to the Alltrax site. It has been extensively updated since I last visited. This is a very young company, started in 2001. This may be the reason they have not had has many controller failures as Curtis.
It is worth going to their site and spending an hour or so. I educated myself on my own controller. Looks like Alltrax wants a pre-charge circuit across the contactor now, before they advertised that the x in npx or axe meant sparkless contacting. I will have to get with Ken at KTA services where I bought my controller to clarify this.
Specs for my npx 4834 controller. 300 amps peak, 275 amps for 2 minutes, 125 amps for one hour. Ramp up rate is 1.5 seconds.
Rating on my Scott 1hp motor, from the motor plate, 41 amps continous.
Rode my bike as hard as I could last night, full throttle at each start. 17 stops from work to home. 5.7 miles. At the end of the ride I put my hand on the motor, was able to keep my hand on the motor for 15 seconds before I felt I would be burned. Outside temperature about 90 degrees. From what Fechtor says, unless spit sizzles on the motor, most magnets will not degrade. So I feel my motor case temperature is probably a little less than 125 F and I should be in the higher end of the safe zone.
Controller, no perceptable increase in temperature.
To repeat on my gearing, belt motor sprocket - 21 tooth, jackshaft belt sprocket - 64 tooth, jackshaft chain sprocket - 14 tooth, wheels chain sprocket - 45 tooth. Gates pg2 drive belt 15 mm, #41 chain final drive. 9.79 ratio.
When I had a 15 tooth jackshaft sprocket, for a 9.14 ratio, I did not have any drive noise, but, the bike did not have as much top end speed and did not have good acceleration.
With the current setup, 14 tooth sprocket, I don't like the chain noise, Stanton Inc. now has a 48 tooth wheel sprocket, I think I'll try that for a 10.45 ratio. The results hopefully from this setup will be I go faster and decrease my motor temp. The chain noise (I just don't like hearing it, it's not very loud) will be eliminated. I will need to put that 15 tooth sprocket back on which will mean a different jackshaft belt sprocket.
I looked at htd belts, I chose the Gates pg2 because of a claimed 3 to 5 db decrease in belt noise. My belt is reasonbly quite and they seem to be very durable.
Thats all for now
chuck
Stleride
Stleride's picture
echuckj5,
We want to add some of the Alltrax Documents to our Fileshare, and EV Controller Collaborative Hand Books which would you recommend?
Stleride
Stleride
MB-1-E
MB-1-E's picture
Tortuga,
I think I will take some readings and apply the V = AR fomula to see what it tells me. I know the motor is rated at 30A Continuous but knowing the resistance (thus max amperage) could prove very benificial.
The next problem that I encounter is finding a controller in the range just above that. As chuck noted a bit earlier, there just don't seem to be any controllers that are perfect for the Scott motors. (FYI, my motor is a 3/4hp Scott and Chuck's is a 1hp Scott both @ 24V).
Hey Chuck,
With what I know so far, I think a 200A controller would handle my motor size well (hopefully applying the information above will help confirm that).
Like you, I don't want to have any constant drain on the batteries from the pre-charge circuit but on the other hand don't want to be dealing with burning up contacts either.
I see that Alltrax makes a 200A but that is the AXE. I sure don't need or want all those bells and whistles. I'll look at their site again to see what they have in the NPX department.
I was checking out a Kelly 200A that has
1 minutes: 200A.
3 minutes: 150A
Continuous: 120A
It is programmable, not a requirement IMO, but it is priced right and seems to be in the Amp range that may work well for my motor.
Don't know a dang thing about Kelly but then again I don't know much about any of the other brands either.
I haven't heard back about my replacement or proposed upgrade yet, but the retailer does carry the Kelly 200A that I was looking at.
I'll have to try several reduction ratios to find that "sweet spot", I will have the means to get a 10.57:1 ratio which may be close (but not quite there). My next step up is at 12:1 ...
... I'll just have to try them out to know.
Thanks for the input guys!
Dave
MB-1-E
Dave B
MB-1-E
echuckj5
echuckj5's picture
Stleride,
Answer to what to add to the controller page:
The axe product family (progamable) and the npx product family (nonprogrammable). These controllers are for brushed series wound motors, including permanent magnet motors like the scott, etek brushed, pmg, advanced dc, and lemco motors. The other product families are for shunt wound and other types of brushed motors.
chuck
Stleride
Stleride's picture
echuckj5 ,
Is this correct?
AXE Mini Manual [Doc100-004-A_OP-AXE-Mini-Man.pdf] Revision A, 439kb, 6/29/2006 [Series Motor Controller] and NPX Mini Manual [Doc100-013-B_OP-NPX-Mini-Man.pdf] Revision B, 464kb, 8/30/2006 [Stock Series Motor Controller]
Stleride
Stleride
mf70
You've gone a long way on this already, but a few thoughts:
You're right that reducing load will avoid that stalled on near stall state. It looks like the nominal 27A load (650W) was at full speed. At stall, the draw is going to go way up. In addition to figuring out stalled current from Ohm's law, you can get an idea of what's happening underway with a BrainDrain, or test in a shop with the Craftsman clamp-ammeter 82372
If you're in contact with the motor supplier, you should be able to get information on what current limiting the motor needs.
MarkF
dangie
Dear Sir,
I have just bought an electric bike. There are a few un-used cables on the controller, and I am trying to figure out what the function might be. Would you be brave enough to make a "guestimate" on what the function might be for each free or un-used cable?
Please see my picture attached to this forum for details: http://www.pedelecs.co.uk/forum/electric-bicycles/1022-control-box-cabels.html
thank you very much,
Daniel Giertz
