HAS anyone ever run a PMG 132 in reverse direction at full voltage?
2 posts / 0 new
getadirtbike
I'm thinking of building a bike running 2 PMG 132's with the output shafts opposing each other. This means hat one will spin in the opposite direction to the other. I understand that these motors are timed, but has hanyone ever run theirs in the reverse direction and had any major problems ???
Patrick
Re: HAS anyone ever run a PMG 132 in reverse direction at full v
Yes, they have. The usual problem is that they burn up.
Perms in reverse have to be limited to 48 volts, and they should be re-timed for the reverse direction.
Patrick
