VECTRIX in the workks-I will be adding to/modifying this machine.
Submitted by marylandbob on Mon, 07/20/2009 - 20:42
Lighting:
halogen headlight, LEDs for others
Number of wheels:
2
I just got this VECTRIX scooter a few days ago, already have 200 miles on it! It really climbs hills great, wish it had a higher capacity LITHIUM battery, and possibility of perhaps 70 mph for short periods. With much difficulty, I have installed speakers an an XM satellite radio tuner with power amplifier. I am investigating lithium battery conversion possibilities, looking for at least 40 amp-hours.-Bob
Heater:
none
Batteries:
unknown brand, 125 volts, 30 Ah, Ni-Mh, about 200 lbs.
Charger:
Vectrix, 12 amperes max.charge current, 125 volt nominal.
Controller:
unknown, Vectrix
Conversion time and cost:
stock, $6,900.00-(with Police extras!-also has XM Radio)
Drivetrain:
Planetary gear, direct
Adelphi, Maryland
Method for 12v system:
D.C. to D.C. converter
Miles as an EV:
200 miles
Motor:
0
Seating capacity:
Two adults
Top speed:
62-65 mph
Typical range:
30-40 miles
Watt-hours per mile:
100
System Voltage:
Vehicle maker:
Vehicle Type:
- eric01
- Norberto
- sarim
- Edd
- OlaOst
Comments
Re: VECTRIX in the workks-I will be adding to/modifying this ...
Welcome to the club! I'm glad to hear of another V here in Maryland, I have not heard of too many. I am in Brookeville.
Your addition of a radio, amp and speakers sounds interesting. I have been thinking of such an addition as well. Where did you mount everything, and how are they powered?
Regards,
Doron
