More E-max Controller Mods - Shunt Resistor Trick
38 posts / 0 new
Last seen: 5 months 4 weeks ago
I finally got to repairing the original controller that failed due to vibration capacitor's shaking loose. Some of you may recall that 1000 miles on rough streets caused one of the phase filter capacitors to come completely detached from the PC board, and the other two had broken leads. Only one capacitor, used as a filter for the 48V power to the MOSFET sink bus, remained connected - it overheated, bulged and melted and shorted the throttle control wires that were touching it. Suprisingly, no MOSFETS failed. So, with the capaciors replaced and the wires repaired, I now have a working spare controller. The only problem was that the 100V capacitors are a bit too tall for the early-style controller case, I had to grind recesses on the case lid. The capacitors are pretty much tight to the lid with the controller closed, but with a dab of automotive sealant on the capacitor tops, they are secured against shaking and are also have a heat sink...
...But, on one of my scooters, I had worse-than expected degradation in acceleration and hill climbing when switched to bigger tires. So, I couldn't resist the urge and added a 1 1/2 inch piece of 12 ga copper wire to the existing three shunt resistors used for controller's current limiter. The shunt resistors are made of an unknown silver colored metal, probably higher resistance than copper but only about 20% the length of the copper wire I added. Nonetheless, I figured with the extra length I would be decreasing the shunt resistance (and increasing current limit) by about 20%.
With the modified controller swapped onto the "slow" scooter, I took it on a test ride. I think I reduced the shunt resistance by more than 20%. The acceleration and steep-hill climbing non- turbo mode is dramatically improved, and in turbo mode is hang-on tight fast! A 12% hill which the scooter (with the 3.50-10 tires) would do no better than 15 mph in turbo now does 20 to 25 mph in _non_-turbo mode. Turbo mode is not needed for normal riding anymore, and I am concerned about burning something out if I use full-throttle turbo to power-up a steep hill or jackrabbit starts.
As expected, this had little effect on level-ground top speed - maybe a mph faster (36-37 mph) - but it sure gets there quicker. So far, with an easy hand on the throttle, I don't think I am experiencing a dramatic decrease in range. I'm sure this would change with a heavy hand on the throttle. I'm concerned about the effect of all that extra current on controller components. Fortunately this is a spare controller, so I can afford to experiment a bit.
I need to fine-tune this shunt resistance ajustment (use aluminum instead of copper wire?) because I certainly overdid it on my first attempt. Any advice would be welcome.
Fechter
Fechter's picture
Good work. It would be nice
Good work. It would be nice to measure the current to see where you're at.
You could use thinner wire or a longer piece to reduce the current. Aluminum is bad, you can't solder to it anyway.
With some reverse engineering, it should be possible to put a small adjustable pot somewhere in the circuit to make the limit adjustable. I think I have this figured out for the PowerPack / Crystalyte black box controllers.
JDELUNA
Excellent work !!!
Just wondering how hard would it be to for people like me that have an used EMAX scooter, if the stock controller were to go bad, to install or replace it with another one like a programmable one ?? I would like to one day upgrade and do 60 volts for some more speed !!!
rgx
Last seen: 16 years 5 days ago
Cool! Where do you get your
Cool! Where do you get your ideas from? Only problem is now I don't know how long I will be able to resist the urge. It wont help the longevity of the motor, controller and batteries. I guess controller components and batteries will take most of the hit.
For fine-tuning the shunt you need to measure the existing one, or find out which material it's made of. Most shunts I've seen were made of copper, maybe it is only nickel-plated? Can you scratch it? For resistors, a metal called "kanthal" is often used. (It's rather a blend of metals, and the name is a trade mark.) Kanthal has a resistivity of 1.45 ohm mm2/m, compared to copper which is 0.0172. At least that sets an upper limit for the resisitivity, all other metals are in between those two.
Other, possible metals:
Aluminium (pure) 0.028
Duraluminium 0.40
Iron (pure) 0.105
Steel 0.16
Zink 0.058
Volfram (tungsten) 0.056
Magnesium 0.046
Note that blended metals have a lot higher resistivity than the pure ones.
Regards,
Rolf
Thanks...
Thanks, everyone, for the comments.
Manipulating the shunt resistors to "fool" the current limiter is admitedly not the most elegant solution.
I really should rig an ammeter and test ride it - where do you find a 0-100 amp ammeter? Or, do you have to rig a shunt of your own and use a milliammeter of known internal resistance?
Also, I probaly need rig something on the bench to measure the resistance of the existing shunt before continuing this exercise...
I think the curent setup won't damage anything with careful throttle use - My wife will happy with the performance, but I'll need to emphasize being easy on the throttle. With well above normal temperatures in the eastern US forecast. We'll be riding through much of December...
Fechter
Fechter's picture
Shunt material
The shunt wires are copper with solder plating. You can measure the shunt resistance with an ammeter and a voltmeter. It also helps to have a power supply that can deliver a constant current. A before and after resistance measurement would allow you to fine tune it. You can also partially bridge between the existing wires with solder to fine tune it.
rgx
measuring high DC currents
You'll need a clamp-type current-meter, unfortunately the ones that measure DC are not cheap. Probably around USD 100.
You can use the existing wiring as shunt. Example: let's say the battery current somewhere passes through a 50 cm, 4 mm2 piece of copper cable. The voltage drop for 100A is then 100*0.0172*0.5/4=0.215 V, highly measurable. It won't be very exact, but gives you an indication. I haven't done this on the e-max, so can't tell you which cable to use. And you'll have to translate the example into US units, like inches and "gauge" for the cable section.
The urge is growing stronger. When comparing with the specifications for the new e-max models, you get a feeling that current limits are set primarily to protect the batteries. 90S (42Ah) is limited to 40A/75A, 110S (60Ah) to 50A/90A. The old e-max motor is rated at 2000W, probably the continous (1h) rating. It can take a lot more during shorter times, as long as it is not overheating. We could hope the controller is able to take some more as well, during short accelerations, but it is probably more sensitive. Other components than the transistors suffers as well when current is excessive, such as the capacitors.
Another reflection is that the shunt is a possible explanation for the e-max's weak performance in hot wheather, since the resistance increases with temperature. I always noticed that performance is best just when you pull away after a longer stop.
Looking forward to hearing more about the current measurement. Maybe have to do some on my own, would be interesting to know what the current really is.
Fechter
Fechter's picture
Ammeter
I use a chinese ammeter and shunt I got from Allelectronics. I set up the shunt (which is huge) inside a piece of PVC pipe with pigtail wires coming out to ring lugs. I replace one of my battery jumpers with this thing when I want to measure. The meter is a nice analog meter with a 0 to 100 amp scale.
Analog meters behave nicely when dealing with harsh switching transients and are easier to read while riding. See:
http://www.allelectronics.com/cgi-bin/item/SNT-100/385/100_AMP_SHUNT,_50MV=100_AMPS_.html
Not really cheap either, but way less than a clamp-on digital thing. It's also powered by itself, so it's always on. They also have a 200 amp shunt.
Shunts
The power wires are 8-gauge stranded or a close metric equivalent. The published diameter for 8-gauge wire is 3.264 mm but how do you calculate the cross-sectional area of stranded wire?
The commercial shunt is probably the way to go. How big is it?
Shunt Temperature effect
Yes, I realized that lower shunt resistance in cold weather was probably the explanation for the improved performance - a good indication of how sensitive the setup is to deliberate changes. I actually got the idea from amother member of this forum who did a similar modofication to his pep-boys Pantera 500W scooter. I think he quickly burned up components on his controller, but this was a far lighter-duty controller and motor than the e-max.
rgx
gauge, and shunt
Wiki has some info about gauge wire sizes, but it is based on solid wires:
http://en.wikipedia.org/wiki/American_wire_gauge
About the shunt, I am leaning towards that it is made of kantal or something with similar, high resistivity. I am assuming that around 0.2 V would be needed for the control circuit (don't ask me to explain that). I found an old picture of the board, maybe you can confirm the dimensions. Let's say the wires are 2.5 mm diameter, and 50 mm long, each. That means the section is 4.9 mm2, and the resistance of each is 0.0148 ohm, three in parallel are 0.0049 ohm, or 0.49 V at 100 A. Seems reasonable. Also means that power dissipation from each at 72 A is around 8 W. Or 3 mm diameter -> 0.010 ohm (0.0034) -> 0.34 V at 100 A, 6 W at 72 A. A bit high, perhaps. (I am using a resistity value of 1.45 ohm mm2/m, but found similar products with values between 1.0 and 1.3.)
Anyway, when you are connecting a similar diameter stranded copper wire, of 5 times the length, the resistance drops to around 0.001.
The ideal mod to the shunt would be to find the same type of high-resistivity wire, and add one in parallel.
(edit: I have yet to learn how to add comments in the suitable sequence.)
Regards,
Rolf
rgx
OEM current values
Now I have done some measurements, but they are not what I expected. I measured on the cables in the battery strings, one string at a time. The cables are 5.8 mm outer diameter and marked 6mm2. In string 1, on a 40 cm section I got 59 mV in turbo mode, max throttle. In string 2, a 26 cm section gave 47 mV. With reasonable values on resisitivity (0.0195, which means copper is not perfectly pure, got the value from a product catalogue), it adds up to around 101 A. In economy mode, current was 53 A. There are many errors in this measurement, but I believe they are within +/- 10% exact.
Regards,
Rolf
rgx
material in shunt in controller
I am beginning to think that the rods are nickel-plated manganin, which is made from 86% Cu, so it might look like copper if you scratch it. Resistivity is 0.43, which gives reasonable values for the voltage drop (pure copper does not). Here is one manufacturer of shunts that uses this material
Shunts
My Results...
OK, here are my results:
I calibrated a piece of 10 AWG stranded (3.0 mm stranded) wire using a battery, dummy load ammeter, and voltmeter. I then cut a length of this wire to make a shunt with exactly one milli-ohm resistance. "Pigtails" were run to an old pocket-sized digital VOM so millivolts are read drectly as amps while riding. The length of the shunt came out to just 28 cm so it fit nicely in the relay box.
First I rigged it to the unmodified scooter. Maximum amperage was limited to 38-40 amps in normal mode and 67 amps in turbo mode. Very close to the advertised values. (Rolf, There may be an error in you resistance assumptions or length measurements for the existing wires.)
Then, I rigged it to the scooter with the modified controller and got pretty much "unlimited" amperage - the maximum reading being 126 amps while powering up a hill at about 35-40 kph - but I probably could have produced an even higher reading at wide-open throttle and lower speed or steeper hills. Only over about 45 kph does the motor self-limit the amperage to 70 amps or less.
Rolf, can you elaborate on your last post? What is the 0.43 value? The resistance of existing shunt? So, with copper wire, I lowered the shunt resistance hundreds of percent?
I'll open one of the controllers and try to measure the shunt resistance directly and report back.
Paul D.
Well, I'd need about 50 cm of the wire I was using to equal a forth shunt resistor. Manganin wire looks hard to find unless I buy 1000 feet of it. I could also go to smaller-gauge copper wire, 18 gauge would get me down to about 10 cm - that could be fit in the controller with a little coiling...
rgx
shunt resistance, and max load current
0.43 ohm*mm2/m is the resistivity of manganin. Dimensions are guesses from looking at a photo. Assuming that the rods are 2.5 mm diameter (4.9 mm2 section), and 50 mm length, the rods will have (0.43*0.05/4.9) 4.4 mOhm a piece, or 1.46 mOhm for all three in parallel. (Lots of uncertainty in that figure.)
According to Wiki, gauge 12 (solid) wire has 5.21 ohms/km resistance, which translates into 0.20 mOhm for 1 1/2 inch (38 mm, is that the same length as the manganin rods?). Anyway, Paul, you might well have reduced the resistance to less than 20% of OEM. Most of the current will go through the copper wire, for sure. I can't tell more exactly, but the conclusion must be: you have disabled the current limiting function more or less. If you want to reduce resistance by only 20%, you need to be more subtle.
And about my measurements, I can't understand what is wrong with them. Possible sources of error are the (chinese) cables might not have the 6mm2 section they claim, or are made of very unpure copper, or my voltmeter doesn't measure correctly, perhaps disturbed by ripple of the current. Or the wires heat up a lot? To get a resistivity of 50% higher than at 20 deg C, temperature must be 150 C. The measured voltage drop was quite stable as well, would have varied a lot if influenced by temperature.
I probably end up buying and installing a shunt, or worse, buying that USD100+ clamp-type DC current-meter I always wanted.
existing shunt resistors
I think existing shunt resistors are actually about 15mm long, and about the same as 12 gauge (2.0 mm) solid wire.
I will be opening a controller up and making a direct measurement and will report back. Adding copper wire to the shunt will be doable if I use smaller diameter and coil the excess length - but then I will be adding a small inductor to the circuit - probably not enough to affect anything?
I found that calibrating a length of wire and making my own shunt was pretty easy - I used a multimeter that can measure up to 10 amps, a spare 12-voilt battery, an automobile taillight bulb to provide a load (an #1157 with both filaments burning is about 2.5 amp at 12 volts) and a second multimeter or VOM. Use a long length for the calibration so you have at least 2 significant digits on the millivolt reading.
You are probably amused by the AWG system which, by the way, is the same "gauge" system used for shotgun shot balls (but not the barrels). But, it gets worse, US electricians refer to the cross-sectional area of a wire in units called "circular mils" Which is the number of equivalent one-mil (.001 inch) diameter wires. I always thought that if we aren't going to go metric (it would be an admission that maybe, just maybe, some "foreign countries" do a few things better than the US), we could at least "decimalize" the US customary system. (We do this in civil engineering/surveing), but the building trades insist on dimensions like "7 feet, 7 and 13/32" inch". There are even pocket calculators available that work in such units.
More Data to Report...
I finally got around to measuring the shunt resistance on my e-max sport, as well as investigating some suitable materials to modify the shunt. I used a small 12V battery and two #1157 automotive tail light bulbs for a 5 amp load, and a 0-10 amp multimeter and a second multimeter for millivolt measurements to make the resistance measurements.
The total shunt resistance on one of my controllers measured at 0.76 milli-ohms (.00076 ohm). Each of the three shunt resistors are about 17 mm long and about 2 mm in diameter. Assuming they are manganin, at Rolfs' previously stated unit resitivity, this comes to 0.78 milli-ohms - very close. So, it looks like e-max controller does indeed use manganin shunts.
My copper wire shunt was probably about 0.2 milli ohms, so I reduced the resistance by about 490% and the new amperage limit would be 190 amps normal mode and and 340 ohms turbo. Way too high.
I don't have access to manganin wire, but I took a steel wire coat hanger out of the closet - the coat hanger wire (1.9 mm diameter) was measured at 1.26 milliohm per inch (0.496 milli ohm per cm) almost exactly 10 times the resistance of similar diameter copper wire. So a very reasonable length (about 2 inches/5 cm) of coat hanger wire added to the shunt should give me the 90 to 100 peak "turbo" amps I'm looking for .
The joys of jury-rigging!
rgx
more current data
I have now installed a 150A/60mV/0.5% shunt, and here are the results. Max current in normal mode 36.8 A, in turbo mode 69.5 A. I must have been greatly mistaken about something in the earlier measurements. Values are in line with what Paul measured, good work Paul.
Maybe I should also add that this from a rather late 2006 e-max sport, assembled probably around February-March 2006.
Regards,
Rolf
Final Result...
Shooting for a new current limit of 95 amps and assuming an existing current limit of 68 amps, the required length of the new fourth shunt resistor using coat hanger wire calculates to 1.5 inches (38 mm)
So, I installed a 1.5 inch long coat hanger-wire resistor, and (after complications - somehow I shorted/burned some MOSFETS on the first controller I tried it - to be discussed later), went on a test ride with the ammeter attached. New amperage limit is 55 amps in economy mode, 96 amps in turbo mode. Spot-on! This gives the scooter enough throttle authority to make riding a much more relaxing experience, allowing me to maintain the typical speed limit on hills up to at least 10 percent.
As a precaution for anyone who else who does this, coat hanger wire probably varies in resistance, so you may want to verify the resistance per unit length of the coat hangers in your own closet before trying this. (I used the style with the thin cardboard tube base, and thinner than typical wire)
GrooveConnection
Batteries are the culprit
According to GAIA germany, a lithium ION manufacturer, the inner resistance of silicone batteries increases during the discharge cycle and reaches a cricital state, where the batteries ability to offer strong surges of power decreases steadily. I have done multiple 20 mile turbo-inundated runs with breaks in between with my E-MAX and can confirm that about a 15-25 min, break is like a miracle for the E-MAX's performance. I do not believe the shunt is accountable for this at all!
Best wishes
GC - You are writing about a different thing...
I am currently running discharge tests that are confirming that the internal resistance of the well-used silicone batteries increases excessively with discharge, limiting their usable energy capacity - but there is very little of your recovery effect that I notice - I f I'm down to the low-voltage cutout point, resting the batteries for a period of time provides only a bit or extra capacity.
At any rate, this discussion as about a completely different thing - giving the e-max more torque (i.e. acceleration and hill climbing) by raising the controller's current limit which is factory-set at about 40 amps for economy and 70 amps for "turbo". These settings appear to be conservative and don't quite provide enough acceleration or hill climbing ability where I live. Adding a makeshift resistor consisting of 1.4 to 1.5 inch (35 to 38 mm) long, 1.9 mm dia. coat hanger wire parallel to controllers existing three manganin shunt resistors raises the maximum amperage in turbo to 95 to 100 amps. This provides greatly improved rideability while still allowing good range if careful throttle technique is used.
rgx
Wire source
When doing this mod, I will probably turn to this supplier
http://www.wires.co.uk/acatalog/manganin.html
And should it come to rewinding the stator, they have the wire. We'll see.
Finally, a picture...
Finally, here's a picture of the installed added shunt.
The new shunt is made of 1.9 mm dia. steel coat hanger wire - it's resistivity is 0.0495 mOhm per mm (actual measurement) It is 35 mm (1.4 inch) in length.
With this added shunt, the maximum amperage is increased from 70 to about 95-100 amps in "turbo" mode, and from 40 to about 55 to 60 amps in economy mode.
BTW, the black paint on the thick wires is what I applied to encapsulate what strongly appears to be asbestos cloth covering on the wires. I don't like the stuff, and the corrupt Chinese factory was apparently unaware that asbestos is prohibited in products sold in the EU, and "voluntarily" banned (due to huge lawsuits) in N. America.
//i109.photobucket.com/albums/n77/PJD123/Shunt_small.jpg)
GrooveConnection
Great!!
Would you assume that this shunt mod works for my E-MAX (one of the 2006 batch with the new Manufacturing code...), bought it in June 2006...
Thanks PJD - and, by the way, hows the scoot holding up, any new findings on the affect the mod has on the batteries??
Re: Great!!
The shunt mod is the same for both styles of controller.
Drill two 2mm holes, and solder in a length of coat hanger wire as described. That's 1.4 to 1.5 inches - as measured from the underside of the PC board. You need to use a 40 watt minimum soldering iron. Just to be safe, short the positive and negative power leads together while soldering to protect the FET's from possible 120 volt AC leakage from the soldering iron.
It is prudent to only use those extra amps when you really need to, and for briefly as possible. You will need to use turbo mode only infrequently with this mod. The mod has minimal efect on the range as long as you are easy on the throttle - just like you would drive a car to maximize fuel mileage.
The first scooter was doing fine with until cold weather and snow curtailed riding. The second scooter which also has the new batteries hasn't been ridden yet. Too cold (some mornings below zero F/-20C) plus snow and road salt. Now, I'm also waiting for a hernia repair to heal up and get over what the surgeon calls "discomfort" (aka excruciating pain).
Kmullee
Re: Great!!
Man these mods are looks more tempting all the time, I’m very curious to see what the E-max can do with the larger wheels and extra current running at 60 volts (maybe melt down the motor, lol). But I’ll probably just start by trying larger wheels. I just picked up 2 more E-max scooters form a dealer getting rid of some stock and I think one going to be dedicated to extreme modding (the other is going to my girl friend). I’m also keeping an eye on the IRFP90N20D. Imagine the E-max controller being able to put out 100amps at 72v or even 96 volts! probably more then enough to melt down the motor.
Also what paint did you use on the asbestos I'm concerned about that also?
Keith
2006 E-Max sport @ 60v
Keith
Re: Great!!
The paint was just some epoxy spray paint I had on hand. Sprayed into a small jar them painted on with a small brush.
Good for you buying wo additional scooters. I'm trying to find someone (like my closest ex-dealers in DC and Bethlehem area) who will sell me just a motor, but they only want to sell a whole (inoperable) scooter. I don't blame them - they not in the junkyard business.
I'd really like to avoid having to add more batteries and weight so I'm looking to modify the motor. Perhaps you should investigate this approach with your spare scooter.
Kmullee
Re: Great!!
Yeah, the larger tires, rewound motor and higher current do sound very promising and looks like the way to go if it works out. But after riding my scooter for a while now with the additional batteries, the weight doesn’t seem to be a problem and the higher voltage does seem to help it accelerate and climb hills a bit better, slightly more then canceling out the problem of the extra weight. Although leaving it at 48 volts would solve the problem of having to use another charger and cutting into your storage space.
So if it works out for you I may just go that route also but in the mean time it’s been great being able to keep up with traffic and zipping around town at the higher speeds. I also just ordered a higher capacity boost battery so I’ll be able to see what the actual range would be in a 60v 40ah pack configuration.
Keith
Keith
leio
Re: More E-max Controller Mods - Shunt Resistor Trick
PJD> Nice idea !
You did the mods on an Emax 1500W or on a 2000W ?
Let us know as soon as possible what is your new range with this mod !
=D-----------born to be wired-------------C8
The mods were on the 2000 watt. I suspect the 1500 amp controller is identical except for a lower max amperage setting. But, the amperage increase for the 1500 would presumably have to be smaller - say 80 amps max.
