Vectrix Gearbox Clunking
Hello everyone...
What's the probable cause of the Vectrix Gearbox Clunking? I've a situation like this one:
Thanks for any help...
open it up and check the bolts that attach the gearbox to the motor
they've been known to snap :-)
no seriously, it's not a big deal to open it up, and at the same time you can change the oil.
that's what I should have done when I first heard something..
Hello everyone...
I'm hoping it's normal....Mine makes exactly the same noise.
Mine too
This noise is normal.
It is called "Cogging Torque".
See this post (and preceding ones) http://visforvoltage.org/forum/4193-mik-question-about-gear-noise#comment-30415 for more details.
Thanks for the recommendation. She's new so the oil should be ok. The Bolts you refer, to check them, the gearbox must be opened?
What's happened with you?
