Extreemly Fast Charging---old info from Genesis
andrew
andrew's picture
Have some old data from Hawker Genesis line of batteries. The following is from graphs for fast charging the 38 ah model (still available). They were charged at 90 amps, then 120 amps inrush current. The temperature peaked at 50 degrees C for the 90a test, and 55 degrees for the 120a test. The charging voltage was 14.7V.
50% Ahr returned after 11.5 min/I=90A
80% Ahr returned after 19 min/I=65.6A
90% Ahr returned after 23.5 min
50% Ahr returned after 8.5 min/I=120A
80% Ahr returned after 13.8 min/I=89.3A
90% Ahr returned after 17 min/I=44.3A
If charging this fast were practical, then this would be one hell of a step for lead-acid EVs. Anyone else got any real data from fast charge testing, done by yourself or manufacturers?
Kmullee
Re: Extreemly Fast Charging---old info from Genesis
I charge my hawker odyssey PC925 28ah at 30amps all the time and It only takes about an hour to charge, I haven’t noticed any ill affects from it yet.
Keith
2006 E-Max sport @ 60v
Keith
andrew
andrew's picture
Keith, what charger are you using, and what application is the battery for?
mf70
There's a poster on the EVDL, Steve Clunn, that uses an electric lawnmower in a lawn-care business, transported by an electric pickup. As I recall, the pickup's pack is 140V, while the lawnmower was a 96V pack. During the day, he "dump charges" the mower by directly connecting it to the pickup.
One of his messages about this is:
http://autos.groups.yahoo.com/group/ev-list-archive/message/60853
According to this message:
http://autos.groups.yahoo.com/group/ev-list-archive/message/75647
He starts the charge at 200 AMPS!
Mark
Kmullee
I’m using an Iota 12 volt 30 amp charger with the IQ module to make it a 3 stage charger. Iota also makes 55, 75 and 90 amp 12 volt chargers so you could really test out their charging rates. I currently use my PC925 in series with the 48v pack on my E-max scooter to run it at 60 volts so it’s subjected to fairly high discharge rates and cycling, although I’ve only cycled it about 40 times so far.
Keith
Keith
