Yet another throttle question
2 posts / 0 new
Ray_T
Ray_T's picture
Does anyone know what type throttle the ego uses? the online manual says "HE" -- is this hall effect? how do I tell?
I ask because I just acquired an alltrax "AXE" to replace the stock, fire-damaged controller because of the programming features and to facilitate future mods.
if the throttle is hall effect, can I use it? I don't see that type listed in the manual. if I can't, what type should I use?
Fechter
Fechter's picture
Re: Yet another throttle question
Yes, the Ego throttle is a hall effect.
An Alltrax controller usually uses a 5k resistor throttle like a Magura.
I'm not sure if the Alltrax can accomodate a hall throttle. There might be a way to dial it in with the software. Otherwise you'd have to get something like a Magura.
