Batteryspace RC Car packs test data
3 posts / 0 new
andrew
andrew's picture
I did some load testing on the 6-Cell RC battery packs from http://www.batteryspace.com because I am anticipating using them to replace lead-acid batteries in my motorcycle. I just need to work out how to build a BMS and charge them.
NiMH 3ah 7.2v test http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=70
After Connector cut off
Charged at 2 amps for few minutes before test
Open C. 7.8v
30 amps: 5.83
50 amps: 5.10
75 amps: 3.174
The load test was only momentary
NiCad 1.7 ah 7.2v test http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=89
Battery 1 after overcharge for about 20 hrs at 250 ma (oops!)
Battery feels warm to hot
Open C. 8.41v
30 amps: 6.5
50 amps: 5.42
80 amps: 3.61
The load was only momentary.
Battery 2 after charge at 250 ma for 7hrs
Connector cut off
Battery feels slightly warmer than room temp
Open C. 8.47v
30 amps: 6.61
50 amps: 5.53
80 amps: 3.75
circuitsmith
circuitsmith's picture
Re: Batteryspace RC Car packs test data
How short was momentary? I'm surprised you could draw 25C from their NiMH with out problems. 63 milliohms @ 30A for either of their packs = 10 milliohm per cell with interconnects.
I'm using Batteryspace 24V sub-C packs (mine are the earlier 3.3AH version):
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2759
I measured 120 milliohm resistance in these packs. That would be 3.6V sag @ 30A.
andrew
andrew's picture
circuitsmith,
I'd cut the Tamiya connector as I found they add considerable resistance.
Each load test was for about 2 sec, and I did the lower rates first. I was surprised I got 47C out of the NiCad pack. That "sintered" electrode must do something. Note that the NiCads have 16 AWG wire, while the NiMH has 14 AWG.
Anyone got one they might want to sell?
My KZ750 Project: here E.T.A. 1 mo
