my bicycle brushed motor have a mistake....
2 posts / 0 new
WINDSHIELD
ok when i acelerate the trottle the motor runs slowly.but when i place the motor direct to the battery it works stronger.i check all the connections and i suppouse are well installed.what is the mistake?i need to fix the motor?ok the nut of my rim was short the circuit of the motor.i fix the problem but right now i lost the performance of the motor. the internal parts of the motor burns out? THANKS FOR THE ATTENTION.
ILBCNU
Last seen: 17 years 7 months ago
Re: my bicycle brushed motor have a mistake....
If the motor runs stronger from a 12-volt battery then there is nothing wrong with the motor. I would be looking at the controller. If the output of the controller was shorted then it very likely it is bad. I would replace the controller now that you know how to connect it.
ILBCNU
V is for Voltage
Moderator captain
P.S. There is no need to start a new post each time you answer. Please use the "Reply" link at the bottom of the post you wish to reply to.
Good Luck!
Chas S.
Moderator Team Captain
