Well, I finally got around to putting Powercheqs on my new Evader scooter, and unlike my old Evader, they seem to work overtime during the charging cycle. My old Evader has a demonstrated range of over 35 miles, and the 4x12Vx35AH battery pack seems well balanced. My new Evader, which is heavier and faster, has a 4x12Vx45AH battery pack, and it's range is under 30 miles. Does the full-time powercheq operation during charging mean that I may have a bad battery in the set?
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
- xovacharging
Could be. Simplest way to check for that is to do a load test on each battery. Depending upon what you have available you can rig something up, like with a coat hanger, car jumper cables, and bucket of water. Or Harbor freight has some cheap load testers.
btw, how fast does your scooter go?
Anyone got one they might want to sell?
My KZ750 Project: here E.T.A. 1 mo
On my e-max, the powercheqs work fairly hard only during the end of the charge cycle when the voltage goes up to 59-60 volts and charging current is low. They also flicker a bit during float as well.
That's interesting. My powerrcheqs also seem to work hardest toward the end of the charge cycle.
My new Evader does and honest 30-31 mph on the flat, and it's a good hill climber. My old Evader only does about 25 mph.
While often justifiably denigrated, the e-max remains among the fastest - and they seem to get faster as they age age. My e-max with 5000 km on it (and a size bigger tires) now does an honest 37 mph on the flat. With the controller modified for 90 amps, it will do 25 mph on grades up to 10%.
