Suggestions for new batteries for E-MAX?
9 posts / 0 new
SMAC
Last seen: 18 years 6 months ago
Hey all,
Well, I'm approaching 3500 miles or kilometers on my E-Max Sport, and the batteries are just about finished with me. I get just about exactly 15 miles to a charge -which is just about exactly enough to get me to and from work, but not much else. I've looked over PJD's and others descriptions of re-wiring batteries, but which brand and how many would you all reccommend?
Thanks, and happy e-motoring
ILBCNU
Last seen: 17 years 7 months ago
Re: Suggestions for new batteries for E-MAX?
SMAC,
I believe you answer can be found here in the post "Battery Pack Performance". PJD has done a lot of testing you may be interested in, you may also want to read the complete thread.
Hope this helps,
ILBCNU,
V is for Voltage
Moderator Captain
Chas S.
Moderator Team Captain
andrew
andrew's picture
digikey http://www.digikey.com looks like the best source for the EVP20-12s now.
Anyone got one they might want to sell?
My KZ750 Project: here E.T.A. 1 mo
BB now makes the "EB20-12" which seems to have identical specs as the EVP20-12. I got them special ordered from a local "batteries plus" store. With only about eight break-in cycles so far, I seem to be getting comparable performance to the silicone pack when it was new.
HCT
HCT's picture
Have some Evercell 24 volt 30A/H batteries pack that have never been used ,OEM price was $ 395.00 , will let them go for $ 295 for one or
$550.00 for a 48 volts twin pack .That is almost 1500 W/H of energy at about 34 Kg , a similar lead acid packs will weight about double .
Any question I can be reached at (203)627-8426 Andre
The e-max squeezes it's batteries in four separate little boxes, the Evercell batteries won't fit in an e-max. And, 1500 watt hours would be less than the stock pack capacity.
HCT
HCT's picture
Hello Paul , appreciate your comments , I am not familiar with the E-Max scooter and area assigned for the battery , could you tell me what is the stock power pack capable to deliver ( watt/hours and at what load current ) have a Lepton-E , been getting anywhere from 30 to 40 miles on a full charge , the person driving it will pretty much determine its range and top speed .
The Nickel-Zinc batteries have a fairly low impedance (less than 50 milliohms @48 Volt pack) could you tell me what did you measure on the stock E-Max power pack , also on the lead acid you got from Digikey .
Would like to complement you on your batteries data presentation , found very informative , how many scooters do you have ? and what kind of mileage do you put on them each week ?.
Regards
Andre
SMAC
Paul, are you using the standard e-max charging port and charger for the EB20-12s? I'm placing an order for them today, and I figured I should order anything else I need at the same time.
Thanks for all your help--(I just downloaded your wiring diagram for the buddy-pairs, etc...)
Yes, the B&B batteries are charged exactly as you did the silicones. The only change is that you should not charge them in with both chargers. The recommended maximum charge current is 6 amps, while both chargers together could be producing as much as 10 amps per battery.
I'd strongly recommend powercheqs or other battery equalizers with the new pack.
