Nowashocki
Nowashocki is an excellent suburban commuter. It passes cars easily, sucks up potholes, and handles well. The regen (typically 5-10%)doesn't really add much range because the best range is obtained when riding like a hypermiler - decelerating so gently the regen doesnt kick in. But who wants to do that? This is about fun and I love regen because I can approach a corner fast, back off the throttle, and it feels like the major compression braking of a 4-stroker! Motorcyclists NEED this feeling! The entire system has worked flawlessly so far. I am very happy with the bike but wish I had spent the $ and put 3x the Ah into it --- LiFePO4??
- eric01
- Norberto
- sarim
- Edd
- OlaOst
Comments
Re: Nowashocki
Congrats!
Of course this is one of the beauties of EVs - you can save your pennies and add LiFePO4 when you feel the need for more range. Or more volts instead :-)
BTW - how is that cowling made?
Re: Nowashocki
First, I wrapped strips of paperboard around the frame and components and covered with plastic packing tape. Then I put on several layers of 3" fiberglass and West System resin over the whole thing - like a cocoon. Then I took a cast cutter and cut through the fiberglass diagonally on both sides and pried the fiberglass off. Then i bolted the two sections back on using some existing fittings on the frame and put a 1" fiberglass tape strip along the bottom edge of the top shell so it overlapped the bottom shell by about 1/2". More plastic tape was put on bottom shell to keep the wet resin and tape from sticking. This made a perfectly matched "overlap" to keep the two sections aligned. I was going to put a few screws through this overlapped section but it fits so well I didn't need to. Finally, I used a 3" roller to apply a thick layer of West System "microballons" onto the cases and sanded them smooth. Repeated, drank a beer. It took a long time and it was not much fun but it does work well.
"Nowashocki" KLR 250/Perm 128/Millipak/regen/4 Odyssey PC928(27Ah-48V)50MPH/10m@25MPH avg/CycleAnalyst/onboard Soneil charger
